    sida's Avatar
    May 2014
    System32
    Default BMW X3 please check file
    I would like if someone can check this file. BMW X3 2.0 D 110kw 2005. The car has black smoke with full gas in time of acceleration. I guess might be bad tuning? Thanks
    Attachment 335966
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Tune was really bad ! In the fact at beginieng i want say is ok, very, very low tune, but then i see boost maps, LOL !
    That's boost map can cause many smoke if add to it some turbocharger problem.
    Anyway - this mod is a crap.
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Boost limit was increased by almost 0.5b so i think that car have boost problem before tune too...
    Checking that file is wasting of time
    sida's Avatar
    May 2014
    System32
    OK thanks for respond. By the way I am not working with tunning, this is my fathers private car and he bought a year ago like this. I would like if someone can repair file or even if someone has original file it would be very helpful. I appreciate it.
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    File Repaired.
    Pls check boost condition, maximum usable should have 2400mbar, can spike only some time max to ~2470
  6. The Following User Says Thank You to CustomCars For This Useful Post:
    sida (14th October, 2015)
    sida's Avatar
    May 2014
    System32
    Thank you for the file. I will write a soon as I get a chance. Thanks again for help.
