Page 383 of 450 FirstFirst ... 283333373378379380381382383384385386387388393433 ... LastLast
Results 5,731 to 5,745 of 6745
  1. #5731
    HeXeN's Avatar
    Mar 2015
    Quote Originally Posted by MrPhilDiag View Post
    Hello guys,
    I have a 2008 donor w164 eis that I need to be renewed to install in another 08 car
    Those 08 can't be read by vvdiprog. Board isn't listed.
    Can't use power adapter . Only 09+
    So my only hope is to insert IR a million times in eis to get password. But I always get error 258 after a few inserts. See picture.
    Any idea what that means ??
    Tried 3 different IR adapters.
    Sent from my Redmi Note 7 using Tapatalk
    It is possible to do all key lost with that type of EIS. Plug ir key to the end. After every error reconnect usb cable and go again.
  2. #5732
    Jul 2015
    I tried to convert some bonus points to tokens but I always get error "Bonus points operation failed". I'm using the android app. Did anyone manage to do it?
  3. #5733
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by gokart View Post
    use OLD app or the NEW one ???
    many thanks to friend kevfield
  4. #5734
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by HeXeN View Post
    yes, easy job for 30 minus +- with little reinsert IR plug.....soon will be available automatic method...
  5. The Following 7 Users Say Thank You to daxxer For This Useful Post:
    Asifmehmmod1 (18th June, 2019), autoTkey (19th June, 2019), Fallen (19th June, 2019), habbyb (19th June, 2019), jonny r (20th June, 2019), milehighlockdoc (19th June, 2019), PremierD (18th June, 2019)
  6. #5735
    Jul 2015
    Quote Originally Posted by daxxer View Post
    The latest v1.5.2.
  7. #5736
    Mar 2016
    Russia
    I’ve got a problem with finding an erase pass for special key 7575602571048203
    Thanks in advance
  8. #5737
    Mar 2016
    Russia
    Quote Originally Posted by jonny r View Post
    Here is your Erase Pass:
    Attachment 627476
    Jonny
    Thanks in advance
  9. #5738
    Quote Originally Posted by vikx View Post
    Thanks in advance
    That looks like a bad Special Key ...
  10. #5739
    Paraguay
    I have the same problem, I use the lasted to
  11. #5740
    Paraguay
    I have the same problem, i use the new app
  12. #5741
    Apr 2016
    uk
    Just exchanged now and it works.
    Make sure you select dealer and fill your address..
    I used new app on Android.
  13. #5742
    Paraguay
    Yes! work ! Thanks !!
  14. #5743
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    *** 2019-06-20
    *** Require firmware V4.5.0
    ===== BENZ V4.9.0 =====
    1. This update no need update the firmware
    2. Add new type for calculate password while all key lost:
    a. Support W230 get key password with VVDIMB Power Adapter (All KEY LOST, 20 minutes-1 hour)
    b. Support W169 type2 get key password with VVDIMB Power Adapter (All KEY LOST, 15 minutes)
    c. Support W169 type2 get key password with slow method
    d. Support W164/W251 2004-2008 (NEC chip)get key password with VVDIMB Power Adapter (All KEY LOST, 30 minutes)
    3. Support write Mark value to NEC key from IR
    4. Support write VIN to HC08/HC12 EIS(Kline)
    5. Bugfix
  15. The Following 14 Users Say Thank You to daxxer For This Useful Post:
    alexxxb0450 (21st June, 2019), autoTkey (21st June, 2019), damih (21st June, 2019), habbyb (21st June, 2019), lagaffe (21st June, 2019), okuser1 (21st June, 2019), rafalgt (21st June, 2019), RG550 (21st June, 2019), rojhat (21st June, 2019), rokibar (21st June, 2019), rola1971 (21st June, 2019), solitaire (21st June, 2019), TeL200 (1st July, 2019), WRX 14 (21st June, 2019)
  16. #5744
    Sep 2013
    ES
    [QUOTE = comizelu; 3605256] Acaba de intercambiarse y funciona.
    Asegúrate de seleccionar el distribuidor y completar tu dirección.
    Usé una nueva aplicación en Android.
    Enviado desde mi MI MAX 3 usando Tapatalk
    [/ QUOTE]
    You tried to change points for tokes but you get this message
    this device cannot exchange tokens, please contact your dealer to update device combine status
  17. #5745
    Paraguay
    Hi mates, I have many troubles whit unlock ESL W204, many time, can´t unlock, and when unlock then can´t write the EIS Data, any ideas, Thanks in advance !!
