Tell them to read Dtc...
And to check under live data, if the values are right related to immo...
trinicolin (11th December, 2019)
ECU not activated. Would VVDI MB do the activation and what is the procedure?
Sent from my SM-G930F using Tapatalk
That's why I am here sir. So i can learn.
hello everyone, i have a mbx s klass, w221, 2013. with an eis issue, part number 2169050000, when inserted the key and turn, nothing opens, like the car had no battery. only miles and trip would display. i read the key, ok. i read the eis, ok. looked like it had an hash error. so, i made a key, took me 2 hours, the car had only one working key. finally made a key. now, it opens the dash/cluster but wont crank. in the cluster, shows KEY INITIALIZING, and nothing happens. i left the key in and cluster open for 5 hours, nothing. i inserted the key in and left it there for a whole day, nothing happened. i inserted the and pulled out the key several times, nothing. i made another key, another slot another type of mbz key. nothing. i am posting the eis file and one of the key files maybe someone can help me to figure this out. i am using BGA type keys and vvdi bga tool. thank you in advance.
trinicolin (17th December, 2019)
Hi mate, I have problems whit a ESL Emulator, he dont write EIS data.. I write and he ever said 0000 all dataSin título.jpg
Any ideas !!
Thanks in advance !
HI,
As I can recall VVDI esl emulator doesn't store Hashs from EIS and few other thing's, but for the car to start it is needed only esl password to be store in memory, the response that the esl sends back to eis is related to data from EIS send to esl and esl password ….
Also status of esl is not activated always ( doesn't get activated when key is inserted and car is cracnked)
regards
Hello everyone, can someone tell me procedure for exchanging the dis on s class w221 with A2169050000 Eis on it? I have the key pass. Thnx
It's possible to recode/reuse used MB BGA key with any tool? e.g VVDI?
I need few explanation if someone have good will..
On few video I see that instead of orange ir adapter other have "regular" be keys case..why??
And second I need to buy nec adapter...so is nec adapter optional one, good for renew nec key and reprogram nec chip for "new" use?? Someone "use" this metod renew/program key or always use new be keys from vvdi??
Thanks!!!
