Page 409 of 450 FirstFirst ... 309359399404405406407408409410411412413414419 ... LastLast
Results 6,121 to 6,135 of 6745
  1. #6121
    Apr 2014
    Quote Originally Posted by adamgr View Post
    yes key has battery and transmitting signal
    was set to 315 but changed it via vvdi mb software to 433 . now sending a 433 signal but not working . key starts car fine.
    not sure what i am doing wrong
    Think this car is keyless go car as has switch on gear stick and button on drivers door.
    could this be keyless go with a ignition switch starter type key too?
    Remove resistor on PCB in the remote.
    Sent from my SM-G930F using Tapatalk
  2. The Following User Says Thank You to trinicolin For This Useful Post:
    adamgr (1st April, 2020)
  3. #6122
    Apr 2014
    This
  4. The Following User Says Thank You to trinicolin For This Useful Post:
  5. #6123
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    What's the fastest way to unlock a w204 Esl Nec . Have been running it on vvdi mb tool for two days now without success
    Sent from my SM-A605FN using Tapatalk
  6. #6124
    Apr 2014
    Quote Originally Posted by autocheck View Post
    Fastest job is use emulator.
  7. #6125
    fastes way is to use a new one!
  8. #6126
    siyadk's Avatar
    Dec 2012
    This key (see picture) customer says suddenly stopped working
    I read this key and can any Mercedes experts say whether this key will work or not, because i dont see many information like SSID, Counter, Key Number. I can read BE key password
  9. #6127
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Quote Originally Posted by siyadk View Post
    This happend when you use cheap chinese key
  10. #6128
    Apr 2009
    RS, BRASIL
    can i have key pass with this, or only pay token
  11. #6129
    Apr 2016
    uk
    Quote Originally Posted by valdirld View Post
    Read eep and you will have pass without token
  12. The Following User Says Thank You to comizelu For This Useful Post:
    valdirld (16th April, 2020)
  13. #6130
    Apr 2009
    RS, BRASIL
    i read by obd, and not retrieve pass, its W164 ml320
    yes, read key nec chip
    i will do this
  14. #6131
    Apr 2016
    uk
    i will do this
    You cannot have pass just by reading eis by obd.
    Better take out eis ,solder few wires,read eep with programmer like vvdi prog and you will have pass..easy!
  15. The Following User Says Thank You to comizelu For This Useful Post:
  16. #6132
    Apr 2009
    RS, BRASIL
    ok, i really think eis more easily, the key can be bga
    thanks for your help
  17. #6133
    Apr 2009
    RS, BRASIL
    hard to take eis, i open key and readout nec chip, programmed a new key sucessfull, but the orig key appear that need sincronize on dash, and not work.
    watth is procedure? same things i have on a class, but bga key
  18. #6134
    Feb 2018
    Does anyone have info wheter the token price will stay 15 dolars or in a couple of months it will go up to 25 or more again?
  19. #6135
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by BeatsByMe View Post
    buy for 1 year it 300usd
