Page 450 of 450 FirstFirst ... 350400440445446447448449450
Results 6,736 to 6,746 of 6746
  1. #6736
    Hampshire
    Is there a problem with Mb server? trying to do data acquisition for a W207, with and without the power adapter, but after 30 seconds, it says fail, i tried yesterday and today, same message, even with power adapter, it says 4 hours, any ideas?
  2. #6737
    Maartinj's Avatar
    Nov 2010
    Data acquisition is collection data from ignition, nothing with server feedback.
    after you collect dalla data- send data to server for result
  3. The Following User Says Thank You to Maartinj For This Useful Post:
    nazz2 (8th December, 2023)
  4. #6738
    Hampshire
    So what's the problem? I tried different port,USB lead ,now when I insert,remove If key,it times out, I tried another Eis,same result, it reads the Eis,Esl, but when chosing lost key, data acquisition,it times out. Noticed the key has been blocked, but since I am doing lost key,well, can these be read by soldering wires to Eis? Not in the vvdi prog menu.
  5. #6739
    Mar 2018
    Quote Originally Posted by nazz2 View Post
    Looks like your EIS cable is bad.
    Without power adapter, data collection is just an hour,
    no soldering is needed.
  6. #6740
    Hampshire
    Thats the conclution i am getting Babeh, but i have 2 rigs set up, and both giving same results, different cable set.
    EDIT. guys this one sorted, it turned out to be a faulty IR reader
  7. #6741
    auto techniek's Avatar
    Mar 2017
    HI
    Any idea how to read this W246 EZS with one connector on bench. Tried with this cable without suc6. cable has this pin connection. see pic.
  8. #6742
    Sep 2021
    NA
    Quote Originally Posted by auto techniek View Post
    HI
    IR with tension towards “acc” I believe
  9. #6743
    Mar 2017
    Anyone can check if this FBS3 or 4 pls
    WDD1760421J010192
  10. #6744
    keymax's Avatar
    WDD1760421J010192
    FBS3
  11. #6745
    Mar 2017
    Bench cable dismantled and tested . Seem no +12 cable was available. Made one and all ok.
  12. #6746
    CaioW's Avatar
    Oct 2015
    Everywhere
    W246 one plug:
    PIN 11 = GND
    PIN 10 = CAN HI
    PIN 9 = CAN LOW
    PIN 8 = 12V
    HI
