giovani (7th July, 2016)
So if we have these two pins - should we remove them?
Sounds logical ...................
autoTkey (4th July, 2016), daxxer (4th July, 2016), derdud (4th July, 2016), duplikeytor (21st September, 2016), habbyb (4th July, 2016)
this extra K-line cable is for use for example with some type of older EZS/EIS, which have his diag PIN in OBD plug in different place then standard norm K-line...for example W203, W639....this models you can read through OBD cable only when you use this BLUE extra cable and connect it to other PIN, in case W203 and W639 have EZS/EIS on PIN nr.1 in car OBD plug...or for use on the table on bench then you can read EZS/EIS through cable too....not only by IR
I tested it so on both car type...W203 ( year 2003 ) and W639 ( year 2006 )
i use in this case very helpful Pin-Out box from the picture there you can connect the BLUE wire to the PIN where you need directly, without any dissaembling OBDplug from the dash and the OBD connection of the cable to the car stay OK and unplugged
habbyb (4th July, 2016), kevfield (4th July, 2016), keyantic (4th July, 2016), neverquiet (26th July, 2016), qwojtus (14th August, 2016)
VVDI now have adapter for NEC or Motorola from ESL/ELV unit....i found it from today moorning on Aliexpress for sale yet
CaioW (4th July, 2016), didi_du_93000 (4th July, 2016), Fallen (4th July, 2016), giovani (7th July, 2016), habbyb (4th July, 2016)
Samic are you trying too flood us with additional adapters? There's new one almost every month.
Question ........ do you want to use the tool to it's full potential ? ..........then buy or make the adapters by yourself and stop moaning .
Guys..
Im trying to read one key version 40.. all good, give me the reading and all, but the option to SAVE the file are not enable..
Im doing something wrong?
Can someone confirm can mbvvdi programing correct remote data in nec mcu 71 and 81 ??
