Page 446 of 450 FirstFirst ... 346396436441442443444445446447448449450 LastLast
Results 6,676 to 6,690 of 6745
  1. #6676
    Sep 2018
    Quote Originally Posted by vov4ik View Post
    A work-around would be - virginize (renew) the NEC ic and then write a new key file to it...
    and what if ezs has no unused slot?
  2. #6677
    Sep 2021
    NA
    Quote Originally Posted by farazfaraz View Post
    In most cases you can use one of the used key slot files for that. Hash can run forward on the key, but it can’t run backwards on the eis.
    Another way to deal with it is erase and write the eis (same as swap). All slots will become free. And then write new keys.
  3. The Following User Says Thank You to vov4ik For This Useful Post:
    farazfaraz (14th August, 2022)
  4. #6678
    Nov 2013
    2004 W209K - neither MB Tool or Autel can add key via OBD. Autel at least reads EIS information via OBD, XHorse can't even read EIS information. Neither of them can read password via IR either. XHorse only read EIS information via IR once, then can't do it. Weird. Original key works normally, no errors.
  5. #6679
    Dec 2010
    Hello . Please need erase pass. Thanks
    4JGBF71E38A306430
  6. #6680
    gomarota's Avatar
    Sep 2009
    please can anyone generate erase pasw?
    EEFA8B03EEFA8B03
    LOVE DK!
  7. #6681
    gomarota's Avatar
    Sep 2009
    re-upppp
    EEFA8B03EEFA8B03
    LOVE DK!
  8. #6682
    Aug 2010
    Quote Originally Posted by gomarota View Post
    re-upppp
    EEFA8B03EEFA8B03
    This is old Half Hash,
    here is your erase password: 14 89 CB 40 C2 42 F6 56
    Regards,
    Jonny
  9. The Following 4 Users Say Thank You to jonny r For This Useful Post:
    ficho (26th August, 2022), immoneard (16th October, 2022), uchtool (21st September, 2022)
  10. #6683
    Sep 2015
    Hello
    help please calculate the code for erasing pass EIS w204
    Special key:
    D7403B60D0283169
    Regards, Serg
  11. #6684
    DK Veteran uchtool's Avatar
    Dec 2010
    Hello
    Please I need the erase password:
    Special key: 333B0C1431633262
    Thank u very much
  12. #6685
    Feb 2014
    This tool's development is totally dead now...
  13. #6686
    Dec 2010
    thank u very much jonny r
  14. #6687
    Dec 2010
    Hello sir
    thank u for yesterday
    please can calc me the erase pass for:
    Special key: 9144000822944102
    thank u very much
  15. #6688
    auto techniek's Avatar
    Mar 2017
    All Benz tools are almost dead because the challenge is FBS4.
  16. The Following 2 Users Say Thank You to auto techniek For This Useful Post:
    gomarota (22nd September, 2022), Willinickersen (22nd September, 2022)
  17. #6689
    Dec 2009
    Ireland
    I need some advetise I have vvdi mb tool and I have problem she is not reading ESL data alwais said [error: not connect to esl or cable problem] if I connect autel I can read some info from esl.
    Someone have solution for this problem?
    Thanks anyway
  18. #6690
    Feb 2014
    Quote Originally Posted by auto techniek View Post
    No, this tool still has what to improve and catch up...
    I'm sure FBS4 solution is possible but not released to the wild for other reasons...
