Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Hi, Down loaded Jag TIs and works fine exept it can't find the Acrobat data files. The acrobate files were extracted and put into a directory named "data". Would you know the correct path that the TIS is looking for to view these files so I create a directory and move the files. Thanks...
  2. #17
    downloading jag tis
    let u know if it works perfect
  3. #18
    Top Poster wiggyshome's Avatar
    UK, ESSEX
    hi
    the data file should be on the disk
    wigyshome
  4. #19
    Default Many Thanks
    Many thanks for the info on this forum
  5. #20
    I am having the same problem with the rear windows. The fuse seems to keep blowing out for no reason. Anyone got ideas of how to permanently fix this?
    Thanks,
  6. #21
    Default Jaguar XK8 - Horn not working
    The horn of my Jaguar XK8 is not working but all other electrics are ok. Could it be a fuse if so which one and where is it or if not a fuse will it be the whole unit needs replacing?
    suen
  7. #22
    After searching for days for this info -- HUGE thanks to those who've posted replies to this thread.
  8. #23
    Thanks guys!
  9. #24
    Member sergiompais's Avatar
    Portugal
    Unfortunately this only provides data until 2004. I have a 2006 XK which was flooded/burned and then rebuilt somewhere. it doesn't even turn the ignition on and i have no techinfo...
  10. #25
    Thanks very much wiggyshome for the JTIS
