Page 1 of 2 12 LastLast
Results 1 to 15 of 25
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Default Jaguar XK8/XKR fuse layout needed
    Hi Guys
    in need of the layout of the fuse box for the above vehicle please many thanks for some reason the owners manual has no info in it. Dealers will do anything to get the Jags in their workshops
    Top Poster wiggyshome's Avatar
    Sep 2009
    UK, ESSEX
    Quote Originally Posted by teerak2uk View Post
    Hi Guys
    Hi i have JTIS which gives you all jaguar tech help including the fuse box lay outs.
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Fancy sharing it please
    Sep 2009
    UK, ESSEX
    hi
    sorry when i get into work in the morning, i will post.
    Sorry For delay
    Here is JTIS
    http://www.megaupload.com/?d=KZOVJ4JV
    http://www.megaupload.com/?d=J4WIHNA8
    http://www.megaupload.com/?d=A2IQ1JLD
    http://www.megaupload.com/?d=TNQ2RV4P
    http://www.megaupload.com/?d=HNCTCN53
    Jaguar Technical Information System
    hi here is your fuse layout hope this helps.
    help please....
    after unrar these files i burned it in a cd and i installed it , and till here everything ok. when i run the aplication it asks me always for the cd.
    how can i bypass this?
    thanks in advance
    tintin2005
    Sep 2009
    UK, ESSEX
    hi
    you can bypass this
    copy the data folder to your computer
    and then you have to tell the software where it is !
    when i get back to work monday i will help more if you cant do it!!
    wiggyshome
    hello my friend..
    what must i change, or where, to inform the program about it?
    what file should i change?
    tintin2005
    hello again
    i?ve already copy \data to c:\jaguar but after analysing all files i could?t be capable of making this to work.
    some help is welcome
    sorry for my english.....
    thanks in advance
    tintin2005
    Last edited by tintin2005; 17th October, 2009 at 11:56 PM. Reason: trying to correct some erros.......hehehe
    Sep 2009
    UK, ESSEX
    hi tintin
    just downloading it again so i can help as i dont have the disk at home
    wiggyshome
  11. #11
    Sep 2009
    UK, ESSEX
    hi tintin
    if you copy the disk to computer then run install from computer the software then thinks your computer is the cd drive and then it will run without the disk
    wiggyshome
  12. #12
    hello from portugal to uk...
    computers are so stupid...
    thanks man ... worked well
    tintin2005
  13. #13
    Nov 2009
    Default fuses
    thanks youv'e helped me out too
    Chris
  14. #14
    Nov 2009
    Default can you send me the fuse box layout for a XKR 2000. I need the cigar lighter fuse loc
    Quote Originally Posted by wiggyshome View Post
    Sounds Good-I need the location for the Cigar Lighter fuse for a XKR 2000
  15. #15
    hi cigar lighter should be on this layout Digital Kaos
