Solafe89 (19th January, 2024)
hello
I have kTAG china clone ,V2.11 fw5.01,
I did update with JLINK for NXP , at first it worked well.After
i forgot to cut internet, it is now blocked all the icons are gray, and now NXP does not want to communicate with JLINK, even with 2.08 version does not work, y'as there a solution without replacing NXP ?
Knowledge creates mysteries.
Need to replace nxp what's your location
I programmed once, a simple update blocks the normal?
Nxp doesn't need replacing, c5555 fix takes 2 minutes, if fw showed 6.071 then it would need replaced. Next time stay offline
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
DashProg (18th October, 2015), Mazolla (3rd February, 2016), Stelaras26 (7th June, 2019), teamtuner (17th October, 2015)
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
DashProg (18th October, 2015), ickko339 (16th December, 2016), mecano_diag (17th October, 2015)
outside forum:
akitossgti (1st March, 2017), fronzethenight (3rd August, 2016), ickko339 (16th December, 2016), mecano_diag (18th October, 2015), pekelan (19th May, 2019)
Problem solved ,thanks for teamtuner
teamtuner (18th October, 2015)
no inernet with china ...
drewdom (14th August, 2016), smirnoff_rules (13th August, 2016)
valdirld (3rd February, 2016)
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
here print
If jlink does not connect you will need to change nxp.
