You can use any kind of bosch bdm adapter if you can made some flat cable for each tool!
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
Anyone have pin out for ktag bdm?
javyb, BDM have and must have universal pinout so it will be that's same like galletto
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
Yes, bdm on ecu pcb is the same. But, how are the connections between bdm needles and the plug on bdm adapter ?
All tools it have different pinout...
Full WinOLS user
like fgtech for sure not...becuase fgtech has them mireored compared to standard BDM
I also wonder about this.
Is pin 1 on the upper right corner?
Here have some BMW examples adapters:
http://www.ecubay.com/
