Results 1 to 10 of 10
    May 2015
    Default Recording to a Sata HDD
    I can record to a usb memory stick on my V8s with no problems, but when I connect a Sata drive several items in the menus are greyed out - everything relating to USB in the Tools menu + PVR and Media Player in the Multimedia menu.
    I've tried two Sata drives, a 2.5 and a 3.5 with it's own PSU - they both give the same effect. Unplug them and the settings re-appear.
    Any advice would be appreciated.
    P&D's Avatar
    May 2010
    What are the drives formatted to NTFS or FAT32
    Hadron's Avatar
    Nov 2012
    E. London
    Do they work OK when you plug them into your pc/laptop?
    May 2015
    Quote Originally Posted by P&D View Post
    What are the drives formatted to NTFS or FAT21
    Thanks for your replies.
    Both these drives work fine on my Windows 7 laptop. They are both formatted for NTFS.
    I had considered trying FAT32, but isn't that limited to 32gb?
    digicon's Avatar
    Jul 2009
    Fat32 is limited to 4GB chunks
    P&D's Avatar
    May 2010
    Hi it defo sounds like a conflict maybe a driver issue........
    May 2015
    Thanks, well my Software version is 3511HD_07_12_2014 so perhaps I should update that.
    However, I don't want to risk bricking it as everything else is working fine and I can live with recording to a memory stick.
    So - I think I'll leave things as they are for the time being, having learned t he hard way" if it works don't fix it" after years of always wanting that bit more!
    P&D's Avatar
    May 2010
    All i can say which is good advice.......Upgrade the box to an E2 system & then you will have some fun & many new doors will open
    May 2015
    Which E2 box would you recommend?
    Apr 2013
    Quote Originally Posted by awt41 View Post
    Any thats have half decent user and seller support for images...images are like customised user interfaces..some are better than others.
