Results 1 to 5 of 5
    RIMKACHIP's Avatar
    Feb 2012
    Default Fiat ducato 2008 programming key
    Hi all, I need help for programming key FIAT DUCATO. After a loss of the key with remote control remains the key to "rescue" that it has no remote control. While the reception of ducato therefore not starting up I saw that the key was being recognized so I read this one with tag and I found that it was the megamos48 !!
    I read dump from BCM and recoded a key !!! no pb ducato restarts !!!!
    Now the problem is the key with remote control !! After research i found a 3-button remote control (rounded chape like fiat 500) but I find that in models with PCF7946 ducato 2008 and I have the key without RF is megamos48 !!!!!
    So my question is: is it really a pcf7946 for remote and megamos48 rescue key (but it seems to me suspicious) or a remote control with a 48 Megamos next ????? so if that's the case how resynchronize tlc ??? thank you I pine and dump bcm !!
    I try to encode a PCF7946 with 95160 dump of bcm but it works only with megamos 48 !!!
    I want to convert hex dump of megamos 48 to dump of id46 !! If it is possible ? i have detected pin adress of dump but the problem is configuration id48 and id46 ??????
    thank you in advance for your help and see you soon !!!!!!!!!!!
    RIMKACHIP
    Envoy? de mon iPhone en utilisant Tapatalk
    RIMKACHIP's Avatar
    Feb 2012
    Problem solved
    EU
    Hello
    Pls how solved this problem?
    Thx
    Have a nice day
    He use probably proper remote. It is only solution wich can work.
    RIMKACHIP's Avatar
    Feb 2012
    problem solved with old key of ducato 2004 id48 , remote is reusable !!!!!
