uploud ori file
uploud ori file
no needed upload ori, all can see without..
Sure file was from some poor beginner not tuner, because only basic map are changed and wrong.
Pressure limiter not touched
Boost map, ~~~~ed up, wrong modiffied
Driver limit not changed so no increase of power..
N75 Map removed !!!! Can broken turbo, always max to 1990mbar
Torque limiter ~~~~ed up.
Anyway without fuel no increase
It's some FREE creappy, modiffication.
Write, customer will be happy :-))
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
thanks bro.. can you make her a good file? i don?t wanna change any turbos
you can use winols
yes certainly but I do not know how to use it . never tried to do it before
thanks mate.. i will try it tomorrow... what ha you do to it?
need the password
i sent you pass trough pm
aprox 110 cv with 270nm
great.. thank you.. i will report back
I dont understand people who hiding files with password. Are you trying to hide your nescience or knowledge? I could understand if you sending someone instruction in details how to work in winols, but you sent him a file that you remaped and NO ONE WILL NEVER LEARN HOW TO DO IT. I guess none of these guys here will not take your job or steal the money which belongs to you.. What is next? Shell I expect password also on dash dump, radio code.....
No hard feelings...
CHEERS
I love smoke ... I just had VCDS on the car. there is only one bar on the turbo.. max 2000 millibar..
