Results 1 to 15 of 20
    Top Poster ettaoussi's Avatar
    Aug 2012
    Default mercedes flap+EGR remove "Inlet port shut off motor"
    Please help me remove EGR and dtc 2513"Inlet port shut off motor" fault code from B CLASS edc16 cdi
    Thanks in advance
    try this and report.
  3. The Following User Says Thank You to saxon1978 For This Useful Post:
    ettaoussi (18th October, 2015)
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Even if someone will erase P2513 from flash that car still will be in limp mode !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Aug 2012
    thanks for the reply! you also remove the DTC 2513 ?
    Dec 2013
    I can make this car with disconnect flap and without limp mode
    Member Takinava's Avatar
    USSR
    I think that is not good idea at all, to eliminate "Inlet port shut off motor" from turbo diesel engine. But, yes it's possible to do, and without limp mode.
    motorsportsz's Avatar
    Jun 2012
    Quote Originally Posted by ettaoussi View Post
    Thanks in advance
    here you are pass in pm
    PRESS THANKS + REP IF MY POST HAS HELPED YOU
    DPF, EGR , ADBLUE, SPEEDLIMIT, LAMBDA, IMMO
  9. The Following User Says Thank You to motorsportsz For This Useful Post:
    ettaoussi (19th October, 2015)
  10. #8
    Aug 2012
    Quote Originally Posted by motorsportsz View Post
    thanks motorsportsz your job worked perfectly
  11. #9
    stanislav georgiev's Avatar
    Oct 2014
    България
    Hi motorsportsz ,can you tell me whether my decision to delete the error code is true. thanks
  12. #10
    Oct 2014
    България
    Can I get some opinions. thanks
  13. #11
    Jun 2012
    Quote Originally Posted by stanislav georgiev View Post
    Send me original and I will do it for you also
  14. The Following User Says Thank You to motorsportsz For This Useful Post:
    stanislav georgiev (22nd October, 2015)
  15. #12
    Oct 2014
    България
    Thanks motorsportsz , here's a file Mercedes EDC 16
  16. #13
    Jun 2012
    here you are mate
  17. The Following User Says Thank You to motorsportsz For This Useful Post:
  18. #14
    Oct 2014
    България
    Thanks motorsportsz ,to the rapid response and professionalism
  19. #15
    Oct 2010
    Dublin
    Hi motorsportsz, can u help me with e270 nedd to remove egr and p2513 and p2131.
