Results 1 to 7 of 7
    Sep 2011
    Usa
    Default iveco diagnostic fault codes
    hello everyone I am having trouble with a 2011 Iveco trakker with a BC and aMET warning.When I check at dashboard the faults are :
    BC221 42 00 65
    BC221 43 00 67
    MET26D C8 06 1
    MET26D C9 06 1
    Icant find a fault code listing for the iveco so any help is appreciated.
    Thank you
    I know that Bc221 is the body module and MET is the chassis module but I cant figure out what the fault codes mean
    Roy Suryadwiananda's Avatar
    Indonesia
    What your Trakker..AD , ADH ...?
  3. The Following User Says Thank You to Roy Suryadwiananda For This Useful Post:
    whalla (19th October, 2015)
    Indonesia
    Or you tried to learn of my the files, perhaps others can also help you later
  5. The Following User Says Thank You to Roy Suryadwiananda For This Useful Post:
  6. #4
    Sep 2011
    Usa
    these fault codes dont seem to be for the trakker I'm working on its a 2011 model with a MET module under the cab. The readout on the dashboard is
    BC221 42 00 65
    BC221 43 00 67
    MET26D C8 06 1
    MET26D C9 06 1
    Apr 2017
    Thumbs up
    Quote Originally Posted by Roy Suryadwiananda View Post
    Gracias , thanks
  8. #6
    Sep 2018
    how can i download
  9. #7
    Apr 2019
    I need to download it too. Could you upload this file again?
