Thread: system check
    Nov 2008
    wite hart lane
    Default system check
    hi people. having bit of trouble with this wii.. firstly i cant d/load all the covers to wii. only 5 or so d/loaded, dont no if you can tell from sys check... also games so not working, here is system check please help
    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.0/4.1E (v54450)
    Priiloader installed
    Drive date: 2006.05.26
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 69547270
    Boot2 v4
    Found 261 titles.
    Found 55 IOS on this console. 3 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug ES Identify Flash Access NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3351): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535 Info: hermes-v5.1): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 65535 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38] (rev 65535 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: hermes-v5.1): Trucha Bug NAND Access USB 2.0
    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
    IOS245[37] (rev 21007 Info: d2x-v7alpha5): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21007 Info: d2x-v7alpha5): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21007 Info: d2x-v7alpha5): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21007 Info: d2x-v7alpha5): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21007 Info: d2x-v7alpha5): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21007 Info: d2x-v7alpha5): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21007 Info: d2x-v7alpha5): Trucha Bug NAND Access USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
    Report generated on 2013/09/25.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    To download covers for game your Wii needs internet access. I don't see much wrong with that sysCheck only you have d2x-v7alpha5 installed. I would suggest you get d2x-v8 which used to be in the Wii downloads section on here but its now missing d2x-v7 is still here. I've just tried to add it back but it says file to big to process 13,750KB. Try Google.
    Keith
    2010 Golf GTD (170)
    Aug 2010
    England
    Ok I've found it d2x v8 Final wad pack.
    Keith
    2010 Golf GTD (170)
  4. The Following User Says Thank You to Keithuk For This Useful Post:
    pudzy (26th October, 2015)
    Nov 2008
    wite hart lane
    m8. where do i put that file, is it in apps
    Nov 2008
    wite hart lane
    ok,, m8 think im all sorted and running again... only thing that seems wrong is games play for a while the freeze, and i need to power off and on agian... thanks for all your help
    Aug 2010
    England
    As instructed.
    Same as always extract this straight into the existing wad folder on your sd card and install with your preferred wad manger.
    I prefer Multi-Mod-Manager (MMM) v13.4
    Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will tell you if your missing any wads.
    Which games don't work all or some give me a list. Some games need to use different IOS's in in USB Loader options.
    Call of Duty: Modern Warfare 3 - PAL - SM8P52 - IOS250
    Just Dance 2014 - PAL - SJOP41 - IOS250
    Boom Street - PAL - ST7P01 - Force PAL60Hz
    The Last Story - PAL - SLSP01 - Force PAL60Hz
    Project Zero 2 Wii Edition - PAL - SL2P01 - Force NTSC not Force 60Hz
    Super Smash Bros. Brawl - PAL - RSBP01 - Force PAL60Hz
    Keith
    2010 Golf GTD (170)
