FGTECH connection. Maybe help You.
hi all
this 2013 must be EDC17C10 PSA SAK tc1797 IRON
ford fiesta 1.6TDCI 95hp
2012 <2013
i have eu kess and tryed read it with it.
but i got falut like > can time out > frame time cut out > mrico wakup. and on on pic.
i then tryed with my tkag wth transdata and it just disconnect after apemt to read it.
i just followed the inst. on ech device. i then when to wikiobd and looked on the diag. over connections and boot pin. and then look in the ksuite again and transdata and then i decovered that the 3 has diffent connections pin on ech picture. and printboard is 100 % idenditical.
when i tryed with connection choosing from wikiobd 1 ground on pin 3 and power to pin 5 that is not in the 2 others pin outs the green light in bootloader was on amidaly. that only can on with 12v preseent on bootloader with kess ang ktag,
wich pin out sholud i follow for getting sugses with reading this ecu.. 20151018_110431.jpg20151018_115926.jpg20151018_121942.jpg20151018_122110.jpg20151018_091531.jpg
BG mads
This kind of ecu with tc1797 have tprot 12 .trasdata cant read because tprot12 plugin is missing.fgtech clone no way.
i try focus 1.6 2013 with the same ecu a few days ago.no chance.
i see in your kess photo the same problem. Cant pass protection......
FILE SERVICE
REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agricultureGenuine WinOLS user
nthanks for the answer is that realy right that we cant get that sug.. to read it. so that a bit sad to hear and you dont think its coonnection problems at all?
the produkt data of car is 9/12 only 2013 model. but i bet you right anyway. <.( BS
Focus that i wanna read a few days ago i think was 2012.conection is the same if you use a multimeter and check is just in another place.this ecu can be read with ori new fgtech.
if you select in trasdata tprot12 you will see a message plugin missing when you try to read.you selected wrong tprot 2/7
FILE SERVICE
maybe this can help
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
not work.i try
FILE SERVICE
you can not do edc17c10 ford, password protected! you can do only edc17c10 citroen-peugeot because dont have password protection for cpu
teamtuner (21st October, 2015)
okay DAME thanks for answering.. so only online tool will do this ecu /.
Try To do this one with FG tech V54
i drop to read this ecu my self. if hafe is saying it can?t then it can?t.. so called our local race tunerrs to hear if they would open it for obd by there CMD.(but hi say it only was abel all time by bootloader so hi souln?d) and for 180eu they will flash it and hi ask me if i had i file for it. i was at the time qiut sure i got one.. but after sometime i start thinking about that i never read it out so i dont have a file for this ecu. i got i ori file for also a 2012 fiesta. but regard to sw hw i dont no. so can i tune the file and use it. i have 2,5 hour driving to the tuners 230km so likewice only 1 chance to get it 200% working then i get home agian so can i used the file ihave or can any help out. i will go there to night so please help me
BG
do not use one file from another car into your car...need to remap Your file...
outside forum:
Yes of course. Thats thumfinger role. situations where orgi is lost some askes for same fole so just thougt it was posibel. I then tune it at there place on my pc then
I read this ECU easily with FGTech v54 and KTAG with no problem. ford number BV61ACD
