Hi gyuz,
may I ask you to extract PIN and CS from the dash-file attached,please?
Thank you.
Hi gyuz,
Thank you.
read confort modul under glovebox
here you are comfort unit
if you need pin and cs also dump from ecu needed. read 95320 either.
I am out of reach the car now. Anyways I am sure the comfort unit contains the info needed as I did this before. There are profs here on the forum able to extract the PIN from it , you'll see, just stay tuned![]()
Hello.
here your order.
pin = 07144
Comp = 67 21 D6 F2 CE 43 AD
MAC = D2 19 0A DC
GJ m8, thx, i will try soon and report.
to AndyCz : here you are the professional I was talking about![]()
PIN code correct - accepted by ECU but not accepted by IMMO - this means I will have to make the ECU immo off to be able to move the car.
May I ask you for IMOO OFF to the attachment please?
Siemens PPD 1.1 5WP45500 AF
Hello.
1) Dear,there is not accept yet the immo off on engine ecu with PPD1.1.
2) what you trying to do on this car let us too know.?
3) look this link may if you accept he can help you...http://www.smok.com.pl/index.php?lan...=2&produkt=147
Thank you this is the story :
I was trying to adapt brand new ESCL bought from dealer according the VIN.
Connected it to the vehicle and tried to enter the PIN you offered me to the IMMO unit 25
IMMO unit refused the key and now there is 255 lock time...
After that I tried to enter the PIN to the ECU, just to verify it is correct and it was accepted it with no problem. So I assume there must have been something wrong in the IMMO before. But the car was OK till this time, except some intermittent ESCL failures.
Now the car does not operate with its original ESCL too - thats is really bad.
Login: 07144
VIN: WVWZZZ3CZ6P037770
pin code is correct
sazimam11 (23rd October, 2015)
Yes it is AS confirmed above. But not accepted by IMMO . I will wait 255 to try this again ...
Hello.
write back the original eeprom in comfort module so after you see the lock time 00.
1) this is the procedure of ESCL adaption by VCDS.disconnect battery negative cable and reconnect,Make sure a battery charger is connected so the voltage is maintained.go to 25-Immobilizer Adaption - 10. Leave channel at "00" Read - Save- Done, Go Back - after Security Access-16 Enter the vehicle PIN in a digit format.(Do it)after Adaption 10,Read Channel 051.test The Stored Value will be 32000. Enter the PIN in the New Value box,Wait | N/A | N/A | N/A Will be displayed. Wait until the ID numbers are transferred into the first 2 boxes.and after Done,Go Back.normally this is which done with my for this job.
Yes I have an evidence about this procedure but for now, as the NEW ESL has locked itself for some reason and I have no more power at circuit nuber 15 (due to internal microswitches) i have no access to the IMMO25 anymore.
must find a way to override this now
With New ESL you do not need to enter Pin, go starring to adaptation Ch 51.
New ESL comes Virgin and it is unlocked , that why no need pin.
