Page 1 of 4 1234 LastLast
Results 1 to 15 of 58
    adam28's Avatar
    May 2009
    UK Essex
    Default XPROG-T or UPA-USB
    Hi guys
    I would like a few opinions on what people think is best XPROG-T or UPA-USB
    I have the xprog-t and was wondering if it is worth getting the upa-usb. what i dont like about xprog-t is it dont work with xp, just the old win 98
    Thanks for any opinions.
    Adam
    V.I.P. Member milanoffracing's Avatar
    Bulgaria,Sofia
    Quote Originally Posted by adam28 View Post
    Hi guys
    Adam
    Xprog-t is very old and support for him is stopped.I recomend you UPA-USB
    adam28's Avatar
    May 2009
    UK Essex
    Whats the difference between xprog-t and xprog-m?
    Bulgaria,Sofia
    xprog-t win98 COM port
    Specifications:
    Motorola microcontrollers (on-board programming):
    MC68HC11A8, MC68HC11E9, MC68HC711E9, MC68HC811E2, MC68HC11E20, MC68HC11G5, MC68HC711G5, MC68HC11N4, MC68HC11F1, MC68HC11PH8, MC68HC711PH8, MC68HC11PA8, MC68HC711PA8, MC68HC11K4, MC68HC711K4, MC68HC11KA4, MC68HC711KA4, MC68HC11L6, MC68HC711L6,MC68HC11P2, MC68HC11F1
    MC68HC11PH8(0H30R Q=614kHz) , MC68HC11PH8(3D64J Q=614kHz) , MC68HC11P2(0G10V Q=614kHz) , MC68HC11P2(1E53M Q=614kHz) , MC68HC11P2(3E74J Q=614kHz) , MC68HC11EA9(2D47J) , MC68HC11EA9(1D47J) , MC68HC11EA9, MC68HC05B6/16/32, MC68HC705B16/16N/32, MC68HC05X16/32,C68HC05B32 (new type from Audi CHORUS),MC68HC05H12(0H57A) , MC68HC05E6(0G72G) , MC68HC05E6(0F82B) , MC68HC05X32(0D69J;1H52A) , MC68HC05X32(0D53J) , MC68HC08AZ32 , C68HC08AZ32(0J66D) , MC68HC08AS60 , MC68HC08AZ60 , MC68HC08AZ60A ,
    Serial EEPROM:
    AT93C46, AT93C46A, AT93C56, AT93C57, AT93C66, AT59C11, AT59C12, AT59C13, CAT24C01, CAT24WC01, CAT24C02, CAT24WC02, CAT24C04, CAT24WC04, CAT24C08, CAT24WC08, CAT24C16, CAT24WC16, CAT24C32, CAT24WC32, CAT24C64, CAT24WC64, CAT64LC10, CAT64LC20, CAT64LC30, CAT93C46, CAT93C46A, CAT93C56, CAT93C57, CAT93C66, CAT93C66A, CAT93C86, 24C01A, 24LC01B, 24C02A, 24LC02B, 24C04A, 24LC04B, 24C08A, 24LC08B, 24C16A, 24LC16B, 24C32A, 24LC32B, 85C72, 85C82, 85C92, 93C06, 93C46, 93LCS46, 93LC46B, 93C56, 93LC56, 93C66, 93LC66, 93C76, 93LC76, 93C86, 93LC86, M6M80011P, M6M80021P, M6M80041P, NM93C06, NM93C46, NM93C14, NM93C56, NM93CS56, NM93C66, NM93CS66, NM93C86A, SDE2506, SDE2526, X24C00, X24C01, X2402, X2404, X2408, X24164, X24165, X2444, X24C44.
    xprog-m Win XP USB Com port Technical Support
    Specifications:
    The XPROG-m programmer is designed to replace the earlier version of XPROG programmer.
    XPROG-m programmer is fully upward-compatible hardware with XPROG programmer and have many additional features.
    The XPROG-m supports in-circuit or on-board programming of Motorola 68HC05 , 68HC08, 68HC11, 68HC(S)12 , HC912, MC9S12, MC9S12X , Texas Instruments TMS370 , MPC5xx, ST10Fxx, ATmega family MCU's and serial EEPROM's .
    All supported devices are divided into "Software authorization" licenses. You can obtain authorization license only for these devices you are interested in.
    XPROG-m Rev. E functional features :
    Fully compatible with all software versions of " Device Programmer Desktop".
    Software update (ATMEGA) - directly from "Device Programmer Desktop".
    Software version control mechanism.
    Self check for error handling.
    Communication via USB 1.1 / 2.0 or high speed RS232 interface .
    Fully upward-compatible XPROG connector.
    Multi functional XPROG-m connector.
    8 pin DIP socket for on- board programming.
    Supports many PLCC, QFP, LQFP adapters for on- board programming.
    High speed hardware engine (PLD).
    Two PWM regulated and ADC controlled voltage regulators.
    K-Line interface pin.
    Hardware Specifications :
    Include high output current MPU.
    External output for on-board device programming.
    Serial port interface (up to 115K baud) works on (COM1, COM 2, COM3 or COM4).
    USB 1.1 / 2.0
    Electrical Requirements :
    Power consumption : 300 mA.
    NOTE:If programmer connects to PC via RS-232 serial port, an external 12V DC power supply is needed.If programmer connects to PC via USB port ,usually an external power supply is not needed, but be sure that USB can supply enough power.
    System Requirements for PC :
    Processor:INTEL Pentium 60MHz or faster (depends on operating system)
    Memory (RAM): 32MB (depends on operating system)
    Hard drive: 5MB free space
    Communication:One free physical COM-port or USB 1.1 / 2.0
    Operating system: Microsoft Windows 95/ 98/ NT/ ME/ 2000/ XP NOTE: USB is not supported on Windows NT 4.0 or early versions of Windows 98.
    Mar 2009
    Xprog-M better than UPA-USB but UPA-USB better for money.
    Reprogram Motorola/freescale cpus best,safest,cheapest way is UPA-USB
    Hi guys
    Adam
    z786's Avatar
    10 Steps Ahead of You
    Default X prog M authorizations
    Hi, i was wondering if theres any way if you bought the x prog m with all adapters, to find a way for all authorizations to be activated without the high price tag??
    Bulgaria,Sofia
    Unhappy
    Quote Originally Posted by z786 View Post
    That's not posible.
    umoussa's Avatar
    Universe
    The new X-Prog is amazin'
    Check www.tmt.lt
    Finally the ARM Micronas has been cracked, it's the End of Immo 4
    UPA is good for Airbag units, In Circuit Programming, however i still prefer ETLWEB programmers
    Umoussa
    www.ecucommander.com
    z786's Avatar
    i have seen on chinese websites claiming they have all adapters and authorizations in the region of $300
    i know their hardware is going to be cloned, but cant that also mean that the software authorizations are cracked????
    thankz
    umoussa's Avatar
    Universe
    Hello M8,
    Don't believe in any Chinese clone. When you talk to any Chinese contact on the internet, they all have the following sentence:
    The device is supporting all bla bla bla, Device is tested, working okay 100%.
    Then you ask them a technical question, they say:
    Must check with our Engineer.
    Then they get back to you and say:
    The funtion or feature that you're asking is not supported.
    Don't waste your time, your clients and your career, go to the original company and save your miond from headache.
    But Xprog with only the features that you need and step by step aquire more modules.
    The choice is yours
    Umoussa
    ECU Commander Studio?
    Hand in Hand to Protect our Efforts - Stop Hunting Our Work
    >>>>>EBAY SELLERS<<<<<
    I'm not Sharing Passwords!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience
    Jun 2009
    UPA-USB has great support and decent programing coverage.
    The only problem i had with upa was the payment witch was i bit of a head ache because a different company managed the receiving payments. Anyway the transfer was done by paypal with no problem , other type of transfer failed.
    umoussa's Avatar
    Universe
    For UPA, i got it using Credit Card payment, it was very easy.
    When i firsted wanted to order UPA, it was out of stock so i had to wait about 15 days or so.
    I received the package very smoothly, then they supplied me with a download link to logon and get all the support materials i need.
    UPA is good, but ETL is the best
    >>>>>EBAY SELLERS<<<<<
  13. #13
    adam28's Avatar
    May 2009
    UK Essex
    Quote Originally Posted by umoussa View Post
    Hello mate
    how much is the ETL and where is the best place to get it.
    And why do you think its the best?
    Adam
  14. #14
    Moderator
    PremierD's Avatar
    Jun 2009
    http://www.etlweb.net/ETL are the best.... But they are all indvidual Programmers...Have browse mate...
  15. #15
    umoussa's Avatar
    Universe
    The price for ETL MC68HC908AZ60 is 180$ + 26$ shipping
    You can contact: Alexey Goncharenko
    email: alex_etl@yahoo.com
    UPA is also good, but i just want to point your attention to a major thing. In circuit programmin for Soic 8 pins is not good and in many cases that causes many problems while reading/programming.
    Also for some MCU, you have to left some legs, so to be safe it's much better to desolder the chip and put it into the adapter and read it by ETL programmer.
    If you are considering this as your career, i'd recommend that you have a look on BK-Precision
    You can get 844USB model it's perfect
    Thank you
    Umoussa
    >>>>>EBAY SELLERS<<<<<
