So i've done a mod on this A4 2007... with 2.0 TDI engine 140BHP standard.After two months the car started to have somekind of wiggle on startup.No smoke, no DTC just at every startup, it has a noise and the engine trembles.I post ORI and MOD files.The file was mooded with ECM Titanium.Thanks for any suggestions!
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
1. Wrong EGR removed by Volta
.... everything is bad, and most creapy boost map..... never try this on any car, NEVER.
Engine broken in possible very quickly
Better remove this file
rly
I don't see worst modiffied file in my life, even by most begginer ! Don't knowig what's they do.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
teamtuner (23rd October, 2015)
CustomCars (23rd October, 2015)
Almost full boost range increase by 1Bar.... that's was crazy... why needed that much boost on ori engine ? That's half more what's that turbo can handle at max and only on specific parts, not all the time...
I will be don't sleep tonight after seeing this... :-)))
too much turbo problems on grim limiters for engine
put the original immediately
For orginal is to late, sure turbo needed replace, engine condition is not sure.
Needed get out pipe from turbo and check condition, then dynamic log all needed parameters at stock software.
Instead of all this critics,why don't you show me the way to fix it. ... I didn't post this to get laughed at... but to get a solution.
All of us say how to fix - write ori, and i give you basic info about checking then. You'r file is TOTALLY BAD.
Did u needed how to diagnose that car, can help, only ask for it, have vcds ?
we dont know what you know....
Ah and not laught from you, or mod because it's crap.. only from funny file name, that's bad ?
And we don't give you file repair solution because very possible you broke that car, at first neeeded DIAGNOSE.
DTC don't show you broken mechanical parts
teamtuner (24th October, 2015)
Bro the file is just ......
You have 2 ways to fix it :
1 - write ori like coleeges says and see how engine is .
2- get a real pro tuned file whit witch car will run verry nice and improtant - SAFE .
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
