Results 1 to 7 of 7
    mislav88's Avatar
    Mar 2011
    Default W169 display type in eeprom
    I have w169 dash with lcd very dimmed, almost not readable. when i put dump from other w169 cluster lcd display is ok, but i have ---- on dash.
    Can someone adapt new dump so it works with my car, or change config in old dump so lcd is ok.
    Dumps and photos attached.
    you need to sync the dash with new dump to ezs with star or with other programs that aslo can sync dash/ezs.
    or if someone know the location where the SSID is and then it copy from you Original dump in to the donor dump.
  3. The Following 2 Users Say Thank You to vageric For This Useful Post:
    mislav88 (24th October, 2015), sagie1zn (6th August, 2020)
    mislav88's Avatar
    Mar 2011
    copied SSID, now everything works fine
    Quote Originally Posted by mislav88 View Post
    can you share the location from SSID?
    mislav88's Avatar
    Mar 2011
    Quote Originally Posted by vageric View Post
    address 29-2C (4 bytes)
  7. The Following 6 Users Say Thank You to mislav88 For This Useful Post:
    ASCM (9th May, 2020), bermuxa77 (24th October, 2015), conan981 (3rd September, 2020), sagie1zn (6th August, 2020), TULGEYWOODMAN (29th October, 2015), vageric (24th October, 2015)
  8. #6
    Integy's Avatar
    Sep 2015
    Hello, I have 100% worked solution for - Mileage, SSID, Service interval and oil sensor (bytes where is located), and the most import of this, for change voltage of LCD in eeprom , from 7V--->8V.
  9. The Following User Says Thank You to Integy For This Useful Post:
    drzewiec (6th August, 2020)
  10. #7
    Feb 2020
    Quote Originally Posted by Integy View Post
    I would like to thank you for your help, I checked your modification and it is working well.
