I have i / o terminal full very good tool update is free for all the modules you've paid for, and protected by a dongle with SIM Card. support is very good and the owner of Andrius is a good man
javyb (25th October, 2015)
you can go...good tool
nice tool, have denso and siemens plugin, tested ecus on bench and via obd, can recommend it, all updates are for free so far.
done 1.7 opel denso via obd, cloned sid803 for psa on bench, and mazda denso rf recently via obd, really good tool.
with io terminal dont work checksum on denso, tested 7 days ago on nissan murano 2.5 tdi 190 hp...wrote file with fgtech genuine and all ok.
There is a seperate option for checksum... you have to checksum the file and then write it using another menu. Look in the drop down menu... it is there.
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
i know, but dont work!
tunertool (26th October, 2015)
I done many Denso remaps with IO Term and allways calc cks with IO Menu option with no problems. It's a good tool.
Got to say its quite a tempting tool!
MPPS Standalone Master, Magpro Base + X17, Dimsport New Genius, Piasini, Galletto V53, Kess V2, K-Tag, Trasdata remapping tools | OP-COM, VCDS, Fiat MultiECUScan, Ford F Super, Renault CAN Clip V124, INPA/NCS Expert + others.
