Results 1 to 11 of 11
    mislav88's Avatar
    Mar 2011
    Default Audi A6 4G keyless start
    I have 2012 A6 with keyless start (not keyless entry, only start) not working. It says key not recognized with both keys, only starts when key is put on dash where key logo is.
    Dealer tried to re adapt keys, change battery, but still the same.
    Remote locking works fine, and there is no single DTC in car.
    Where to start with this one, BCM2 fault, antenna?
    Apr 2011
    in lebanon
    Quote Originally Posted by mislav88 View Post
    Hello.
    1) please tell me,you mean when you insert the remote key in ignition he start, but if you leave some where it in the car, and cant start the car by using push start bottom? this you mean?
  3. The Following User Says Thank You to haroutioun For This Useful Post:
    mislav88 (25th October, 2015)
    mislav88's Avatar
    Mar 2011
    yes, only there is no ignition slot but you just hold key by the key mark near the cd (this work even with battery out, guess there is just a simple transponder read coil)
    Apr 2011
    in lebanon
    Hello.
    OK i understand.i think not BCM2 problem,this antenna problem,did any body dismount the doors to check if sound system stop or central lock window?,i am asking cause always i am getting same problem, and that was the problem when they reconnect door accessory lick speakers connector,so here the connector of speakers & antenna of key-lees are same look,so try check them,maybe some who insert this wrong place.
  6. The Following User Says Thank You to haroutioun For This Useful Post:
  7. #5
    mislav88's Avatar
    Mar 2011
    i will check that, where is antenna located? note that this car does not have keyless entry, so no antennas in door handles.
  8. #6
    mislav88's Avatar
    Mar 2011
    a little update, there is no antenna in doors as it has only keyless go, not keyless entry.
    i also noticed that when you press start engine button led on key flashes a few times, and then i get "key not recognized" on dashboard.
    is there a way to resync it?
  9. #7
    Apr 2011
    in lebanon
    Hello.
    1) i just load this pics of location antenna with R138 + R139 + R200 + R201.
    2) you can re-sync your remote (4G0 959 754 K) but by obd2, but in your past post you try at the dealer sync no? and no result,so i don't know what tool you have in your hands, you can test in (Meas.Blocks) the antennas,if you have odis this tool he can help you step by step to arrive at solution.
  10. The Following 5 Users Say Thank You to haroutioun For This Useful Post:
    cjawahir (14th May, 2016), marius7593 (25th April, 2024), mislav88 (26th October, 2015), Siham (14th May, 2016), triak88 (20th May, 2016)
  11. #8
    mislav88's Avatar
    Mar 2011
    yes dealer deleted the keys and re adapted them again. i have vcds, vas and odis.
  12. #9
    May 2016
    Hi guys, I bought yesterday and A6 c7 2012. It has 2 remote keys and both of them need to be placed on the dashboard in order to start the car. I changed the battery in one of the keys and it's doing the same.. any thing I can do or just go back to dealer? Cheers
  13. #10
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Flash in PCF7945AC is corrupted.
    Only solution is to reflash PCF7945AC or new Keyless-GO key.
    Change your batteries more often.
    If battery goes below 2.8V brownout failure happens when you press the buttons,and flash gets corrupted.
    Same as Audi A4,you code in the remote,the remote gets accepted but nothing happens on button press.
  14. The Following 3 Users Say Thank You to simaservis1108 For This Useful Post:
    armpower (22nd May, 2016), obdsystems (19th May, 2016), paskuale (18th March, 2025)
  15. #11
    May 2016
    Quote Originally Posted by simaservis1108 View Post
    is this for my problem or for some one else? When I press start the key led starts to blink , and after 2-3 sec it's asking to place the key on the dashboard. Any idea how much is a new key? cheers
