Hello to all members of DK,
Please who can tell me how to read and write tool
this ECU.
K-TAG 6070 (clone) the can 'read and write
if you can do you give me info link.
Thank you all for your help
this ECU.
From what car is it? year?
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
Hello Friend,
Thank you for your answer
This ECU is a JCB excavator
I don't think you can read/write with 6.070
70max (27th October, 2015)
Thanks for your help.
Best regards
Hi my friend,
I can not find in my Family 701
K-Tag
Is it very bad on my 6070 (clone)?
This exists in your family?
Thanks for your answers
This is connection for this Ecu but for that you need Ori Ktag with 7030 firmware if i not mistake/ anyway higher then 6070 and as i know china clone doesnt have higher firmware then 6070.
disonlu007 (19th December, 2019)
Ktag 7.020 reading and end reading error checksum...
I have on the table 2 ECU DCM3.3+ and i could read both of them with firmware KTAG 7020 if anybody need flas file can contact me. One of the flash file from notprogrammed ECU so you can do ECU is new before installing. But now i have error in writing. as KTag manual says its need only 4 wiring to write this ecu but i tryed several times both of my ecu and no succes. Does anybody tried and what result? Thanks
Color pcb your ktag?
i cant see because on it warranty stiker and afraid to remove it. but acually its eu clone. do you think it can be because of that?
From what seller you buy?
i have same problem with read this ecu . then read but same error checsum erorr
i want scr off please enyone help thk
Same problem with ktag 7.020 , cannot read
