Results 1 to 4 of 4
Thread: SID803 DPF off
    mislav88's Avatar
    Mar 2011
    Default SID803 DPF off
    Hi folks, i need dpf off for P407 SID803 ecu, original files attached.
    Thank you
    Andrei2015's Avatar
    Oct 2015
    Default dpf off
    dpf off file. enjoyAttachment 338117
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
  3. The Following User Says Thank You to Andrei2015 For This Useful Post:
    mislav88 (27th October, 2015)
    mislav88's Avatar
    Mar 2011
    have another one, this time SID803A, hope you can help me again
    obd read attached
    motorsportsz's Avatar
    Jun 2012
    Quote Originally Posted by mislav88 View Post
    obd read attached
    here you are
    PRESS THANKS + REP IF MY POST HAS HELPED YOU
    DPF, EGR , ADBLUE, SPEEDLIMIT, LAMBDA, IMMO
  6. The Following User Says Thank You to motorsportsz For This Useful Post:
    mislav88 (28th October, 2015)
