dpf off fileAttachment 338451
Please can someone help me with this file. I need to do dpf off. it is MB class B 180cdi edc16c32 ecu.
mercedes.zip
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
mecsoun (28th October, 2015)
Thank you very much. Your help was really fast. try it tomorrow in the car but I think it should work. inscription how it works. thank you
Dont work. I have dtc 2359 and limp mode :'(
With original software do you have limp mode because of dpf?
With original file is without limp mode and dtc is only 2084. With your file is limp mode and dtc 2359 and i have disconnect sensors
What sensors have you disconnected? Try my file but connect all sensors, only difference pressure sensor and dpf temperature sensors have to be disconnected
I disconnect only diff sensor and temp sensor. I tested with and without sensors. Problem is limp mode and only one dtc 2359
try this one. same passwordAttachment 338655
I go to try
the problem is still the same
