Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Member roby's Avatar
    May 2009
    Jupiter
    Default SKC from Audi A4 dashboard
    Does anyone knows wich soft and wich interface has to be used in order to read I**o (4 digit SKC) from AUDI A4 1.9 TDI Y2000 with dashboard part no. 8D0 900 920 ???
    Vag Commander k+can 1.4 doesent read this dashboard only ECU eeprom.
    Jul 2009
    Quote Originally Posted by roby View Post
    Does anyone knows wich soft and wich interface has to be used in order to read Im$o (4 digit SKC) from AUDI A4 1.9 TDI Y2000 with dashboard part no. 8D0 900 920 ???
    Try vag tacho 2.5 interface.
    calculate pin: tachosoft, imm$killer
    May 2009
    Jupiter
    Vag Commander 1.4 in Engine ECU haves im$o off function did anyone tried this and I would appreciate any feedback regarding this.
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    lets try and not use the word im*o please on this forum is a miss used program and we we all know wot it does just add a letter in as l have in the above posts , it stops people finding this place when searching on google for that word if u get m8 .
    give this cant be done l will just remove every post with that word in
    May 2009
    Jupiter
    Quote Originally Posted by smirnoff_rules View Post
    Ok I agree with you but Im afraid that lot of newbies will not understand only I*** words i think we could run to explanations of initials then used by us.
    Mar 2008
    birmingham
    l will see if admin can add auto edit for that word and just add 1 star as above
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    SuperVAG K+CAN may help you
    Dec 2010
    RO
    HLP ! I have an a4/1.8/ADR/1995 and dashboard work chaotic...I have an 93c56 eeprom on it...can send me a damp for it ? PLS... it is an UK_NSI dash Magnetti Marelli I think ?!...(AU_0004_001)...Ty !
    YESSSSS!!!
    I'm found it !
    8D0 919 033 D...the "D"...is not so clear but...dash have 6 clocks...is OK ?!
    Jul 2010
    U.S.A
    vag number from the dash? 8Dx xxx xxx....
    Dec 2010
    RO
    wow...?! I only seen...AU-0004-001...where could be that...?!...on a pce of paper ? or what ?!...PLS...guide me pls...Ty
  11. #11
    unu's Avatar
    Oct 2010
    EUROPE
    Quote Originally Posted by albundy64 View Post
    on paper ... like 4B0 xxx xxx (x)
  12. #12
    Dec 2010
    RO
    Quote Originally Posted by unu View Post
    YESSSSS!!!
    I'm found it !
  13. #13
    Dec 2010
    RO
    Quote Originally Posted by maumaumau View Post
    YESSSSS!!!
    I'm found it !
  14. #14
    Dec 2010
    RO
    YESSSSS!!!
    I'm found it !
    Can you help me ? pls...
  15. #15
    Jul 2010
    U.S.A
    some dumps for uk nsi...maybe one of them will help you...
