Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
  1. #46
    Dec 2018
    Small program for post 36 fix.
    100% not tested and the fix differs from the dumps/fixs posted by other users but this does exactly as post 36 says
  2. The Following 13 Users Say Thank You to vectrac20tsri For This Useful Post:
    alejandrobr1995 (8th January, 2022), asdfghhh (5th April, 2021), gaben8 (6th January, 2020), iwcham1979 (10th October, 2019), mr G (28th February, 2020), mymyk (24th February, 2020), neospeedo (14th August, 2021), ninja123 (6th March, 2019), pedro222 (2nd August, 2022), rm23 (5th May, 2020), rtbdiagnostic (21st October, 2020), SKODANIKOV (15th April, 2019), will4u69 (4th March, 2019)
  3. #47
    Dec 2010
    wales
    Hi all, I used the script in post 36 and can confirm this is the fix.
  4. The Following User Says Thank You to highbury For This Useful Post:
  5. #48
    poland
    Default fix problem L-R DOOR
    I am asking for help, I have repaired the file according to the instruction I have got ======= but the door has been converted L-R.
  6. #49
    poland
    ---------- WHERE FOLLOWED FAULT -------------
  7. #50
    Apr 2014
    can some one explain what post 36 means and how to fix the eprom dump? i understand the address but what do i change it too?
  8. #51
    dashradio's Avatar
    Inafield
    Quote Originally Posted by sjc1 View Post
    Post #36
    It tells you the hex position,
    it then tells you what to write in that position.
    You must write every position.
  9. The Following 2 Users Say Thank You to dashradio For This Useful Post:
    Johnner (14th March, 2020), sjc1 (16th April, 2019)
  10. #52
    Mar 2013
    Warsaw
    I think there is a bug in solution from post #36. After use it there was some cluster configuration change eg LHD to RHD change.
    Wysłane z mojego VTR-L29 przy użyciu Tapatalka
  11. #53
    Sep 2014
    my solution is only tested on lhd but change back with mdi easy
  12. The Following User Says Thank You to Sarah1331 For This Useful Post:
    teerak2uk (9th May, 2019)
  13. #54
    Mar 2013
    Warsaw
    Yes,
    Yours solution change some cluster configuration bits and becose that, some functions may not work correct or may not work at all.
  14. #55
    Sep 2019
    Same problem, missing vin in cluster
  15. #56
    Jun 2018
    I did with this soft and everything is ok ...
    Insignia is a 1.8 benz 2008
  16. #57
    Feb 2016
    hi guys, have same problem , ------ on clock, can somebody fix my file? I did try solution from post 36, but is no working on my file. Or maybe somebody have same file as mine to share?
    Cluster no 12843885 SW 05.54'
    Thanks in advance
  17. #58
    Apr 2012
    Europe
    could someone fix my dump from bcm Zafira C ?
    Dash not displaying km.
  18. #59
    Feb 2016
    Does anyone have a solution for repairing the Opel Insignia 2015 BCM EEPROM 24C32?
