Resolve your problem by changing the inlet flat actuator - motor . It is a bit of stripping down but i think this will be the best way .
Sent from my SM-N910F using Tapatalk
Hi, is there anybody who can disable the intake flap on this car? Audi A4 2.5TDI with EDC15VP ECU 1MB.
Car has these DTC:
01282 - Intake Manifold Flap Change-Over Valve (N239)
19558 - Motor for Intake Manifold Flap (V157): No Signal
if I Disabled these error, car still has limp mode around 120km/h - So make only DTCoff is not good!
Please help me
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
Yes you are right but I wanted to know if there is a way to disable this flap.
hi
you can build one small regulator with NE555 to bypass swirl flaps,all parts not are more than 0.99 euro
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
If same as Mercedes only needs a resistor on motor plug!!!!
