hi youre file dtc off
pass PM
pass PM
REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
furnata (2nd November, 2015)
Galetto dont want to write the file....only original . maybe somethink in cksumm?
Im here to help and to be helped
Yes you must delete ols checksum.
I can do but later
try this
pass same
nice work bro....dtc is gone but still have blinking check on dash ....maybe must try other solution
ok i have other solution later i do
furnata (3rd November, 2015)
Boomer i hatе you! you are amature :P
boomer any new idea
anyone else
Help your self. You must calculate checksum
furnata (6th November, 2015)
thanks friend dtc is gone but still blinking check on dash........i give up
maybe the vin in ecu is wrong....someone to check vin inside eeprom? i cannot see it maybe crypted?
furnata (7th November, 2015)
