dtc p0602 off. If is not working I need full bdmAttachment 339259 read
Someone to help delete this code P0602 in this Vectra
Thanks in advance
0281011449
370821
bdm vectra c all_Flash.rar
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
carbon7319 (2nd November, 2015)
Thanks Andrei i will try this file but just in case i will post full bdm now.
vectra c bdm.rar
0602 all offAttachment 339344
carbon7319 (3rd November, 2015)
Thanks again my friend.
I will flash this tomorow and report.
Little bit late but let's talk about DTC off.
When i flash file with DTC off on this Vectra ewerything was ok , no lights on dash , car run nice and on OP-COM no DTC errors.
Today i made diagnostic with Tech 2 and ..... yes error P0602 its present , no lights on dash car run nice.
I put OP-COM to do diagnostic and ...... no DTC present .....
What happend guys ????
Did you cleared it? it reappeared? I can't remember if I have provided bdm with dtc off or just obd
You made for me both , full bdm and flash.
Same to both files.
And yes , i try to clear doesn't want to be cleared with Tech 2.
Its not problem , i just want to know the reason if someone know.
I'm also courius... No fault with op-com and fault with tech ?
I know that fault in DTC table could be listed more than once in edc16C39 but it doesn't make sense to me. Diagnostic tool shouldn't make difference.
VAG
