Results 1 to 2 of 2
    Default skybox f5s help plz
    i have a sky f5ss box i used to use my old pc with the com port to reflash i now have the usb one and it sincs says done then says stb error any help please and thans in advance
    Hadron's Avatar
    Nov 2012
    E. London
    Are you using the correct upgrade tool for your box? There are a few versions around for different boxes which will give the "Set stb memory error" if used on the wrong box.
    Also what type of USB to serial adapter did you get? Some of the cheaper ones do not work correctly with these boxes.
