Results 1 to 4 of 4
    Member paddybongo's Avatar
    Jan 2009
    Default iphone stuck on activation screen
    hi can anyone help i just bought a iphone 4s and its locked to 3mobile and it stuck on the activation screen and i dont have a 3 sim to activate it.
    Any help be much appreciated,
    DK Veteran johnboy1974's Avatar
    glasgow
    Put the device into dfu mode then connect it to iTunes where you can restore the firmware. It will always look for a 3 SIM card unless you ask 3 to unlock the device.
    Feb 2017
    You need to connect with iTunes and make sure the cable you use will not have the disconnect issue. I used to transfer data by using plastic cable and it disconnect while transferring and everything sucks. So I changed to a metal piarmor cable and use it to do everything again. Everything goes perfect. The connection tool is important.
    May 2017
    let it deload until it is emptz, then load and restart.
