Results 1 to 9 of 9
    DK Veteran shaunfree's Avatar
    Nov 2008
    lancs
    Default vu zero gui stretch
    hi all having probs with gui screen with BH image(small gui) ie when i open autobouquets it is small my gui seems to be in middle and not stretched across screen cheers shaun
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Not on bh at the moment but should be sorted out in settings.
    Nov 2008
    lancs
    thanks doug how would i sort with settings cheers shaun
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    As I said not on bh at moment using vix and menu-system-settings-user interface-position set up. So should be something similar in bh. hth
    Nov 2008
    lancs
    thanks again doug tried ui position plugin but makes no differance to the gui screen cheers shaun
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Have you tried other images to check? Picture screen is okay I assume it's just interface.
    Nov 2008
    lancs
    hi doug yes picture ok just interface what is small,when i open autobouquets and try to set up 4 region i cannot see what iam selecting cheers shaun
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    BH image press green button now in green panel scroll down to and select UI position setup select left/width/top/height whichever one you want to adjust Then use D pad on remote to srtetch or minimise interface. Then save it press green button. hth
    Nov 2008
    lancs
    thanks doug tried that but gui is in middle and cant seem to stretch it to full screen as it goes just left or right cheers shaun
