Results 1 to 5 of 5
    Sep 2010
    Default Nissan Denso 2.2dci - check DPFoff solution
    Hi, please check file for DPFoff for Nissan 2.2dci with Denso ECU.
    thanks for help!
    Problem solved
    Sep 2010
    nobody can check nod for DPFoff?
    Babos's Avatar
    Mar 2012
    Quote Originally Posted by vopi View Post
    I check for you all is bad!
    Sep 2010
    OK and is there anybody who can help me with correct solution for this ECU/Car?
    motorsportsz's Avatar
    Jun 2012
    thanks for help!
    Inside zip archive is original and DPFoff file
    here you are
    let tool correct checksum
    PRESS THANKS + REP IF MY POST HAS HELPED YOU
    DPF, EGR , ADBLUE, SPEEDLIMIT, LAMBDA, IMMO
  6. The Following User Says Thank You to motorsportsz For This Useful Post:
    vopi (5th November, 2015)
