Page 126 of 146 FirstFirst ... 2676116121122123124125126127128129130131136 ... LastLast
Results 1,876 to 1,890 of 2176
  1. #1876
    Junkyard Dog thank you once again, it works perfectly
  2. #1877
    Jul 2017
    Hi I have p1564 permanent fault code cant clear it on a fiat marelli mjd 8f3 What do i need to buy to enable read and write to the ecu with please ? Many thanks
  3. #1878
    Aug 2019
    hello, pelase remove DTC P0036 BMW e60 530i (second lambda faulty) be sure to count the checksums, thank you !!
  4. #1879
    Jan 2020
    Default Dtc off in denso ecu
    Hi Looking for Fault Code Delete in this file Please Its for Denso Ecu on JAGUAR XJR 4.2L
    P0016
    P0018
  5. #1880
    Apr 2019
    Hi friends..
    Can you help me to check or repair this files is it good or not?.
    Suzuki Escudo 1.6L gasoline.
    Ecu Mitsubishi 33920--50J8.
    Mcu MH7203FA.
    Thanks before.
  6. #1881
    Mar 2018
    Romania
    Please help me!! I need dpf-off for Audi A4 2.0 tdi, 03G906018AQ, PPD1.3.
    I did DPF off with DPF Remover but don't work , does not accelerate more than 2800 rpm and i get an error P2563 turbocharger Boost control position sensor circuit . Thanks in advance , please help me!! I have attached both files.
  7. #1882
    Mar 2018
    Romania
    I'm sorry , This is my original file .
  8. #1883
    Jun 2018
    Bulgariq
    Quote Originally Posted by lovinedi03 View Post
    pass-PM
    Thancks and Reputation
  9. The Following User Says Thank You to naskochipa For This Useful Post:
    lovinedi03 (27th January, 2020)
  10. #1884
    Mar 2018
    Romania
    Quote Originally Posted by naskochipa View Post
    pass-PM
    Thanks! Checksum is ok?
  11. #1885
    Apr 2019
    italy
    Help
    ford focus 2008 edc16c34 2.2 1037395211
    DTC OFF P0380
    I have tried other 2 solutions but not working.
  12. #1886
    Oct 2018
    bytegiga
    hi 2 diferent solution test and report
    thnx button and send pm pass
  13. The Following User Says Thank You to tothzsolt For This Useful Post:
    bytegiga (5th February, 2020)
  14. #1887
    Apr 2019
    italy
    Notte working soluzione yours
  15. #1888
    Apr 2019
    italy
    Needed some really working solution
  16. #1889
    Aug 2019
    hi, i need to disable errors. 00562 - Sensor for Oil Level / Temperature (G266), 010 - Open or Short to Plus
    And 16985 / P0601 / 001537 - Internal Control Module: Memory Check Sum Error. Passat b6 2.0fsi med 9.5.10
  17. #1890
    Jun 2018
    Bulgariq
    Quote Originally Posted by prezesik18 View Post
    pass-PM
    Thanks and Reputation
  18. The Following User Says Thank You to naskochipa For This Useful Post:
    prezesik18 (8th February, 2020)
