Hello
Can you try remove DTC from this ECU ?
Renault Master 2.5 DCI 120hP
BOSCH EDC16C36
1037383334
Read through BDM
DTC for remove:
-DF209
-DF647
Thanks in advance.
Hello
BOSCH EDC16C36
1037383334
Read through BDM
DTC for remove:
-DF209
-DF647
Thanks in advance.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
locarno (9th January, 2016)
[QUOTE=locarno;2680033]I know these DTC's are from EGR. For EGR I have ASC solution (look attachment), but DTC DF209 still active. DF647 disabled.
If you can help I will be grateful
errors removed
locarno (10th January, 2016)
Please i need DTC off for my Mercedes B W245 180cdi 2006,
Fault code to be disabled: P2100.
EDC16C31
Thank you.
Hi. Plesae dtc off in edc17c14 VAG P14A6 05286 . Thanx very much. Regards
thanx, best all
Hi, can you send pass?
Thanks!!!
Hi, can you send a pass?
Thanks!!
Can you please remove DTC P1421 from Peugeot 307 2.0 HDI EDC15C2.
DPF off is already done.
Thanks.
ditjon0000 (13th January, 2016)
