iwdm (5th July, 2022)
Need to remove dtc p299 from vw 2.0 tdi 140 bkd u can?
hi i have a hitatchi ecu for a nissan titan 2008 and its hitatchi sh7058 chip and i need dtc off on codes p0118,p0223,p0123,p04481ZR15B8ZHFAUN5-20220708-132547 nissan titan.zip
plz if anny one can help me i cant find anny one with the experience
Hi can you please remove DTC P0600, it is also going into a limp mode. any chance of changing maps so it doesnt go into limp mode? EDC16C31 Mitsubishi Canter 4M42 engine.
Cheers,
Hello, I need to remove or eliminate the dtc p0230 from the edc15c2 unit of a Fiat Scudo 2.0 JTD RHZ, the vehicle goes into emergency, thanks in advance.
Hey guys, can you delete error code P0102 maf signal low (16486) from this file please? Ori is a3_ori and mod is a3_mod. You can do it on either and I'll copy the solution to the other file. Many thanks!
Dtc remove is not solution for solve your problems.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
krook59 (9th September, 2022)
Someone can me Dpf and Egr off from this file from Mitsubishi Canter Fuso 0281020139. Thanks in advance.
Citroen C3 Delphi DDCR need dtc off
P0400,P0402,P0704,P1351
Thanks!
please egr off thanks
ford connect 1.8 tdci sid202 hw cafr1a40fr1a400 sw 10154596aa
