Hello again.
I have some A4 with flaps DTC's to be done. Customer want's to ged rid of the problem for good (he has replaced the flaps anyway befor with no resaults).
P0480
P0691
P2008
P2015
P2016
Mega Thanks.
Hello again.
P0480
P0691
P2008
P2015
P2016
Mega Thanks.
Hi, everybody,
Volvo/Ford ME9 393284 Ford Focus ST mk2.
I found these necessery DTC errors masks for rear lambda sensor and catalyst diag.
P0420, P0421, P0422, P0423, P0424, P0036, P0037, P0038, P0136, P0137, P0138, P0139, P0140, P0141
and disabled it.
P0420 - 1D61E6-1D61EA
0036, 0037, 0038, 0054, 0136, 0137, 0138, 0139, 0140, 0141, 2270, 2271, 2A01
1D61CA-1D61D1
1D6222-1D6224
1D620A-1D620D
P0423 - 1D6146
Is it enough to disconnect rear lambda sensor or the engine will go into limp mode?0261209048 - ST stock.zip
pike (26th February, 2016)
Thank you!
I'm afraid of I only remove CE in that way, but main procedure is going wrong in limp mode.
If you interested, I have some selfmade (checked) mappacks for volvo/ford me9.
Hello!
I need off P0428 on edc16c34 ford focus 1.6tdci Num. SW: 1037395209
I removed dpf on this file flash ori dpfoff.rarwith 1 switch(all looks ok) , but probably the temperature sensor is faulty.
here you have dpf off and dtc off corrected !
you can disconnect all you want from dpf !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
marmaro (28th February, 2016)
THX! for reply
"you can disconnect all you want from dpf !" - you mean temperatur sensor from fap, and
differential pressure sensor ,and controller of supplement to tank too?
Best regards
please remove p0660. Edc16c39 vectra C - ori in attachedTHX
Please remove DTS P0101 ECU edc15C7 Fiat ducato 2.8 jtd
