Page 44 of 146 FirstFirst ... 3439404142434445464748495494144 ... LastLast
Results 646 to 660 of 2176
  1. #646
    spiridonas's Avatar
    Default BMW X6 EDC17CP46 DDE8 erase the fault code 4530
    Please can anyone edit my dump to erase the fault code 4530 ?
    "4530 Boost Pressure Actuator - Regulation Pressure too low"
    Many thanks in advance.
  2. #647
    Jan 2014
    Default DTC oFF iaw 5sf9.A8
    Please i need DTC oFF for Fiat Grande Punto with ECU IAW 5sf9.A8
    DTC : P1305
    5SF9.A8 G.PUNTO .rar
  3. #648
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Quote Originally Posted by nazaeas View Post
    DTC : P1305
    Test this file...
    The checksum MUST be calculated by your tool!!!
  4. The Following 3 Users Say Thank You to bobolin4o For This Useful Post:
    DashProg (29th May, 2016), nazaeas (27th May, 2016), pike (26th May, 2016)
  5. #649
    Jan 2015
    Hey gents,
    Can you please help remove 28B4 DTC in this file? The fault is "Valvetronic servomotor, sluggish movement" and the ECU is an MEV17N46 on a 320i BMW.
    Yes, all VVT, eccentric shaft, cabling, etc has been replaced already and this fault only comes up once or twice a month. The car pulls perfect so in this car that setting is just a little too sensitive.
    Thanks for all your help
  6. #650
    Nov 2008
    Thumbs up
    My problem is Solved
  7. #651
    Aug 2015
    campo grande, brasil
    Default hello i need dtc off
    hello
    Please you can let do dtc off to this file
    Peugeot Boxer 2.3 Mareli MJ8F3 DTC P1205 / P2453
    Thx
  8. #652
    Hey I need DTC off and Emissions EVAP, 02 htr, and secondary air off along with a pending dtc code 1790 off for a bmw. YOur PM list is full, can you email me.. mavallone997@gmail.com Need file asap.
  9. #653
    mihaiservice's Avatar
    http://www.quick-tuning.com
    For wich user was the request ?
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  10. The Following User Says Thank You to mihaiservice For This Useful Post:
  11. #654
    bobolin4o's Avatar
    For topic starter is supposing...
  12. #655
    baltazar3's Avatar
    Andromeda
    Renault Vel Satis 2.2 dci need to remove DF209 (EGR Valve position sensor)
    many thanks in advance !
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  13. The Following User Says Thank You to baltazar3 For This Useful Post:
  14. #656
    bobolin4o's Avatar
    Here is your file.
  15. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    baltazar3 (28th May, 2016), DashProg (29th May, 2016)
  16. #657
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Quote Originally Posted by bobolin4o View Post
    Bobolin4o, nooo :-)
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  17. The Following User Says Thank You to CustomCars For This Useful Post:
    bobolin4o (30th May, 2016)
  18. #658
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by baltazar3 View Post
    Stll have DF209....will try tu cut fat wire (+12V) on connector.
  19. #659
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Just cut (two) fat wire. Works if your possition sensor in EGR valve is OK.
  20. #660
    bobolin4o's Avatar
    But EGR is still active in the file (i suppose), i don't check it...
    So you will have and error for the actuator...
    Probably i had not deleted the DF209 properly... let another one will delete it!
