Page 5 of 146 FirstFirst 123456789101555105 ... LastLast
Results 61 to 75 of 2176
  1. #61
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    please if possible remove P0400 and P2466...egr ...and sensor of water on fuell
    saab 9.3 engine 1,9 edc16
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  2. #62
    Jul 2011
    saab egr off.
    no dtc
  3. The Following User Says Thank You to draganelektricar For This Useful Post:
    teamtuner (2nd December, 2015)
  4. #63
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    I have vw tauran 2003 1.6fsi my ecu write what : med9.5.10 maybe you can delete P1340 dtc of this ecu ?
    tauran 1.6fsi 2003year med9.5.10 P1340 on.rar
    Thank you for help.
  5. #64
    Jul 2012
    Quote Originally Posted by teamtuner View Post
    I read this section and see that as free rein to use the software but without understanding whether the answer is correct ...
    my advice
    The file does not contain P2466 does not exist ..
    if you want a solution that works off dtc off EGR you should read the complete file bdm ... This file contains P0400 but the file has a partial reading and disable P0400 may not work properly ..
    please read the file bdm
  6. The Following User Says Thank You to mario38 For This Useful Post:
    SAYMEN (8th June, 2020)
  7. #65
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Exclamation
    Quote Originally Posted by bmw320d View Post
    Hi CustomCars you can remove this error P1446 and P1361 from edc16c34 of peugeot partner 16hdi 90ps
    Thanks in advance
    pls check
    Sorry all for delay and only few helps last time. Not much time for helping. But soon, will be much better and everyone will be able to count on more rapid support in every case.
    I will provide little more help free DTC off on more ECU's.
    Like ME7.3, 7.9 and EDC17C49, SID807, DCU, DELPHI, Denso,
    All VAG ECU like PPD1.5, MED any type, all EDC17. But for many of them needed more time..
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  8. The Following 2 Users Say Thank You to CustomCars For This Useful Post:
    bmw320d (2nd December, 2015), pike (2nd December, 2015)
  9. #66
    bmw320d's Avatar
    Help I need remove error P1427 and P2620 in ecu edc16c31 bmw e60 530d 235ps
    Thanks for support
  10. #67
    Usa
    Default GOLF 5 1.9 TDI EDC16U34 DTC P0546 OFF PLEASE
    Can you do DTC OFF P0546 for this EDC16U34
    file is DPF OFF
  11. The Following User Says Thank You to lokher For This Useful Post:
    bebac (7th August, 2016)
  12. #68
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by mario38 View Post
    my advice
    thanks mario38 for answering...yes,is strange that...even with egr off done,tested with autocom if is done ok (egr rest off),i have thoses 2 P code...verry strange...and also the message on display for acqua into fuell sensor...ufff
    outside forum:
  13. #69
    borysgo2's Avatar
    Please remove if possible:
    P2143
    0489 - manufacturer specyfic
    P1351
    SID803A peugeot expert 2.0hdi
    THANKS
  14. The Following User Says Thank You to borysgo2 For This Useful Post:
  15. #70
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Thumbs up
    Quote Originally Posted by borysgo2 View Post
    P2143
    P1351
    THANKS
    Always for correct SID solution needed made full BDM dump.
    Your file attached
  16. The Following User Says Thank You to CustomCars For This Useful Post:
    borysgo2 (4th December, 2015)
  17. #71
    hello
    volvo
    hello ihave volvo xc90 2006 i need dbf off i reding flash ecu number
    volvo
    30729826 a
    bosch
    0281012103
  18. #72
    Default volvo
    volvo
    volvo
    30729826 a
    bosch
    0281012103
  19. The Following User Says Thank You to almlohe For This Useful Post:
    richardos47 (29th August, 2017)
  20. #73
    borysgo2's Avatar
    The dump looks the same as one from DTC Remover SW, it does not work in my case.
    Thanks !!
  21. #74
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Thanks !!
    So your tool make it good. Like i say.. for correct case needed full BDM.
    Whats problem still have ?
  22. #75
    Apr 2014
    GB
    I need some help. Please remove DTC 1622 (ELAB) and limp mode from MB w220 S320CDI. 0281010067, auto transmission.
    Attachment 345002
