Page 45 of 146 FirstFirst ... 3540414243444546474849505595145 ... LastLast
Results 661 to 675 of 2176
  1. #661
    dominik.m's Avatar
    Jun 2009
    POLAND
    HI.
    VW PASSAT 3B0906018F SIMOS 3 1.6l
    Is it possible remove dtc from this ECU?
    17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
    P1423 - 35-00 - -
    17811 - EGR System: Regulation Deviation
    P1403 - 35-10 - - -
    THANKS
  2. #662
    Oct 2013
    Hello!
    VW passat 2.0 TDI ppd 1.1 please remove DTC P3101 flap
    flap ppd.rar
  3. #663
    Jun 2015
    Asturias, Spain
    [Quote = Spiridonas; 2777080]? Por favor, ?alguien puede editar mi volcado para borrar el c?digo de error 4530
    BMW X6 EDC17CP46 DDE8
    "4530 Boost actuador de presi?n - regulaci?n de la presi?n demasiado baja" . Muchas gracias de antemano [/ quote]
    hello, here dtc off file, please check and correct checksum, treat and inform, password private BMW X6 (4530 DTC OFF) - - - O_7ALJGO352A - 515071 - Bosch - EDC17CP45.rar
  4. #664
    Dec 2015
    Hi .
    I need please DTC OFF 0420 0136 0137 0141 0170 0410 0400 0401 0402 0403 0404
  5. #665
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Quote Originally Posted by dominik.m View Post
    HI.
    P1423 - 35-00 - -
    P1403 - 35-10 - - -
    THANKS
    Here you go... P0000 probably, without MIL on...
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  6. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    dominik.m (1st June, 2016), pike (31st May, 2016)
  7. #666
    Dec 2015
    Good afternoon ! You watched my file, or you can not?
  8. #667
    bobolin4o's Avatar
    Apr 2010
    Quote Originally Posted by spasq View Post
    No damos - no joy.
    Regards!
  9. #668
    Jul 2010
    italy
    Default freemont edc17c49 dtc p2453
    hi,
    dtc p2453 dfp pressur
    Fiat freemont edc17 c49 defap end egr off
    freemont 764 originale no fap no egr.zip
  10. #669
    Feb 2011
    Hi ,can you remove 16485 - Mass Air Flow Sensor (G70) P0101 - 35-10 - Implausible Signal - Intermittent
  11. #670
    huskypt's Avatar
    Apr 2016
    PT
    I need delete 2 errors :
    P2100
    P2122
    Seat 2.0 140HP - 03G906016FH
    Thank you
    Attachment 379329
  12. #671
    Aug 2009
    hi
    remove please dtc
    P3193
    P1098
    audi a4 2.0 fsi
    0281S01023
  13. #672
    Jul 2012
    Quote Originally Posted by dlm View Post
    Seek help and enter the password in your file !!!!!
    if you do not want others see your great work alone solve your problem
  14. The Following User Says Thank You to mario38 For This Useful Post:
    blazej1200 (6th June, 2016)
  15. #673
    Jun 2012
    Hi I need remove dtc P0400 from ecu Marelli 6F3, car Suzuki Swift 1.3, year 2008, ecu nr 33920-72KQ1MAG, engine D13A, 55 kW, I attached file read by Galletto
  16. #674
    Dec 2015
    Italy
    Default Error on AUDI
    Hi to all,
    can anyone halp me to delete dtc p0401 on audi file attached? Thank you
  17. #675
    Nov 2012
    hi, i want remove dtc p2241 lexus gx470, anybody help me?
