Results 1 to 3 of 3
    Nov 2012
    Default skybox f3 not booting
    guys
    have a skybox f3 that is not booting(well it boots then soon as it reachs 100%it starts all over again, and keeps repeating). Should i load a new firmware onto it? and if so can that be done via USB? or is my box done
    Dega
    P&D's Avatar
    Hi have a look here .....Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    No the box cannot be flashed via USB
    Hadron's Avatar
    Nov 2012
    E. London
    Could also be due to a short circuit in the LNB cable. Does it boot OK with the LNB cable removed? If so, you could remove the LNB F plug, cut off an inch & redo the plug.
    It could also be due to failing capacitors on the power supply board. The tops of the capacitors should all be flat (as in the photo). If any are bulging, then they need replacing. They are the 6 black tubular componets with silver tops on the right of the photo. You might be able to see them through the grill in the top cover.
    http://i01.i.aliimg.com/img/pb/917/4...499917_502.jpg
