Maybe it needs to be recoded with VAG KKL cable and VAG-COM software?
Hi Br.
Please help with remove multitronic (automat). After remove miltitronic ECU not accept new coding with manual gearbox. Audi A6 03g906016gc Bosch EDC16U31 0281012169 engine R4 2,0TDI BRE. Read Galleto4 from OBD. Dump with DPF OFF.
Thanks in advance.
Read ecu only bdm and write flash from manual. Test 100% ok
GC is only mulntitronic no code maual. Write bdm flash MH auto work ok
Hi Br.
Problem solved. Write full BDM dump, with immo off, eeprom, flash and MPC. Car start, coding accept. Here full dump for BDM100. Bosch 0281012112 03G906016GB. This version for manual transmision.
Thanks for all.
Hi, maybe somebody knows what to do in order to auto start and after switching off the ignition and gave the key?
Today I wrote bdm flash from Pawel11 and the car start ok. The ECU accepted manual coding.
Does someone know what to do to take key out after replace automatic transmission with manual ?
After reserch I figure that after remove the trim of switch their is a small hall on the ignition switch were push and the key came out.
