kinketotua (11th October, 2018), xpto (25th July, 2018)
Thanks gonna try
Sorry but no work.still lose power and acelarator dies...
Did you cut the signal from the MAF?
Yes.just leave the pins from temp sensor
And have error only for the MAF?
Sorry, but this solution is tested on about 15 cars till now... No complaints...
Check again.
johak (25th July, 2018), kinketotua (11th October, 2018)
Ok.i think i found the problem.i think its a demage pipe that goes from turbo to intercooler.thanks
Hi all.
Please P0102 DTC delete.
help me please disable maf please
which file did you use for the resolution? I asked for the passwd in pvt but no answer .. can you give me the solution? thank you
problem solved
No way to give you the password, mate...
Joined 2 years ago, with two posts...
The other thing is, that i don't know the passwords for my files, because every time i just scratch on the keyboard when type them.
So, i can told you just one thing - if you want to solve your problem, post the file here...
Hi friend,can you do maf off on citroen c3 1.4 16v delphi ecu?
