Page 71 of 73 FirstFirst ... 21616667686970717273 LastLast
Results 1,051 to 1,065 of 1084
  1. #1051
    DK Veteran NZBrakelathes's Avatar
    Aug 2010
    Zibo Shandong China
    Quote Originally Posted by AEN View Post
    It does not seem correct. Firstly, this shop offers GX3 to the abroad market, while Launch International sells them in China, international version called Master.
    Secondly, prices are less than OEM prices.
    The GX3 can be total fake factory units too just like Diagun - many not made by Launch etc
  2. #1052
    soundnavigator's Avatar
    Sep 2010
    Guys, I have the problem. I tried to change original 1 GB SD card with others ( 2 GB and 4 GB ). I format it in FAT32 as original and copy all files from original to second card. Finally with original kard the toll work, with second have error. Does anyone have any idea where is the problem?
    BR
    All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
    Our database available for download 24/7 on EVC server for all legal WinOLS users
  3. #1053
    Aug 2010
    Zibo Shandong China
    Quote Originally Posted by soundnavigator View Post
    BR
    Max 2gb class 2
    Can't use hcsd card etc
    Needs to be slow
    Isn't it FAT format for duagun?
  4. #1054
    Aug 2010
    Zibo Shandong China
    BR
    Or do search here
    Dll file in PDA can be chanted to accept upto 32gb card
    The answers are here on DK
  5. #1055
    DK Veteran sergej's Avatar
    Latvia,Riga
  6. The Following User Says Thank You to sergej For This Useful Post:
    soundnavigator (13th June, 2013)
  7. #1056
    Sep 2010
    Quote Originally Posted by sergej View Post
    MicroSDHC in Diagun.
    1.Connect Diagun with PC via ActiveSync
    2.Unpack and copy file from dll.rar in ResidentFlash.
    3.Copy in registry from SD.zip with Registry Workshop
    4.Reset Diagun.Your Diagun vill see microSDHC.
    5.Install Microsoft? .NET Compact Framework 2.0 SP2 in ResidentFlash.
    Download .NET Compact Framework 2.0 SP2 Redistributable from Official Microsoft Download Center
    6.Copy your GAG in microSDHC and test software Diagun.
    Thanks mate, but how to do point 3 ?
    BR
  8. #1057
    Sep 2010
    I tried, but maybe broken the registry. Now I can't start and with ori SD Card. How I can resolve the problem ?
    Can anybody export driver registry in HKEY_LOCAL_MACHINE or all backup registry ?
    BR
  9. #1058
    Latvia,Riga
    Delete "\ResidentFlash\" from HKEY_LOCAL_MACHINE\Drivers\BuiltIn\SDBusDriver in DLL= \ResidentFlash\SDBus.dll;
    HKEY_LOCAL_MACHINE\Drivers\BuiltIn\SDHC_SMDK2440; HKEY_LOCAL_MACHINE\Drivers\SDCARD\ClientDrivers\Cl ass\SDMemory_Class;
    HKEY_LOCAL_MACHINE\Drivers\SDCARD\ClientDrivers\Cl ass\SDMemory_Class\High_Capacity;
    HKEY_LOCAL_MACHINE\Drivers\USB\FunctionDrivers\Mas s_Storage_Class
    Registry Diagun
  10. The Following User Says Thank You to sergej For This Useful Post:
  11. #1059
    Sep 2010
    Thanks again sergej, I restore and make backup registry, but again I cant start with second card. Diagun see the card, but have error when start the software. I not install Microsoft? .NET Compact Framework 2.0 SP2 in point 5, how to do this ?
    BR
  12. The Following User Says Thank You to soundnavigator For This Useful Post:
    sergej (13th June, 2013)
  13. #1060
    Latvia,Riga
    2.
    Install Microsoft? .NET Compact Framework 2.0 SP2 in PC
    When run install automatic open windows ActiveSync and ask about folder=Resident Flash
    3.
    automatic open windows in Diagun-set update in Resident Flash
  14. #1061
    Latvia,Riga
    Then open HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETCompactF ramework.
    In 1.0.3316.0 set=0
    In 2.XXXXXX set=1
  15. #1062
    Sep 2010
    Hi sergej, I tried all option but I can't start software with others 2GB card. I attach my registy, if it possible check it. Maybe I'm doing something wrong.
    Thanks in advance.
    Best regards.
    Diagun_registry.rar
  16. #1063
    Latvia,Riga
    Registry OK.
    What error message?
  17. #1064
    Hungary
    Yep. Bleeding was perfect. All of my friends' E39s from Europe to NZ have softish brake pedal.
    Mission accomplished.
  18. #1065
    Aug 2010
    Zibo Shandong China
    Quote Originally Posted by ivicz View Post
    Strange??
    Maybe cause RH drive rods? Or you saying there soft scots ?
