A method of disabling the protection CRP3 microcontroller LPC2478.
This method does not allow the reading of locked memory microcontroller.
arvedo (16th November, 2015), autocentarvu (14th October, 2018), BlacksunLE (7th April, 2017), choro (16th November, 2015), cipijoint (13th February, 2018), dorofteius (15th November, 2015), Dutsov (24th November, 2015), Faraday (15th November, 2015), FlameFenix (16th July, 2017), florinyes (22nd November, 2015), francisnikson (28th March, 2017), gazvts (15th November, 2015), Geza (29th April, 2016), kaosforall (17th March, 2016), kevfield (15th November, 2015), klonone (13th June, 2017), lupu_sandu (15th November, 2015), moky (16th November, 2015), morcegao (5th April, 2016), p9776 (30th January, 2016), proginfo (29th February, 2016), puiu (21st November, 2015), stefaudio (30th November, 2015), tatyanka (23rd April, 2016), tawaf111 (28th April, 2017), toms4 (15th November, 2015), totalfree (18th November, 2015), valdirld (16th November, 2015), vasco fernandes (19th November, 2015), wen20v (30th January, 2018), will4u69 (15th November, 2015), xirtam (16th November, 2015)
AIDIN R O (29th February, 2016), andkl2810 (16th November, 2015), andy99 (16th November, 2015), araby80 (26th November, 2015), artkiani (17th August, 2016), choro (16th November, 2015), Dutsov (19th November, 2015), Geza (29th April, 2016), kaosforall (17th March, 2016), kevfield (15th November, 2015), lupu_sandu (15th November, 2015), mamanacusa (20th May, 2016), micromax (15th November, 2015), morpee (28th January, 2016), p9776 (15th February, 2016), puiu (21st November, 2015), stefaudio (30th November, 2015), tawaf111 (28th April, 2017), valdirld (14th September, 2016), vasco fernandes (19th November, 2015), yellowstilo (16th November, 2015), zyjekrc51 (13th December, 2015)
Good work friend.
Probably the success rate is not 100 %, but it is a good solution.
We thank you alll.
Dutsov (19th November, 2015), Geza (29th April, 2016), Ginocar (10th December, 2015), gopelhu (27th January, 2016), kaosforall (17th March, 2016), lupu_sandu (25th November, 2015), mohamedkey (16th June, 2016), pinotec (15th November, 2015), puiu (21st November, 2015), stefaudio (30th November, 2015), valdirld (14th September, 2016)
try ,but When I connect pin 148 mcu > 3.3v
led red not blink
Good find,MCU is susceptible to power glitch.
Not that susceptible to power glitch i guess. Thinking how things work, i suspect the trick is that after certain ammount of heat the microprocessor cannot read properly the flash content upon initialization, if just one single bit of the CRP3 pattern gets changed/corrupted the bootloader not enter/obey CRP3 mode inmediately and allow bootmode to kick in. Guess after that, the only operation allowed without recheck for CRP3 pattern again is FULL ERASE, that's why you cannot read MCU content once it cooled and have access to flash again. This is all theory/educated guess, haven't tested myself over a real MCU.
j-link You can read, is to try but always the same failure
no read target memory
have you try with ktag?
I see it takes two tools,
flash magic + j link.
I have only jlink I can do it, or do I need another tool where I can buy, Greetings
arvedo (16th November, 2015), kaosforall (17th March, 2016)
need connect 12v ?
my led red always off if not connect 12v
Good find, will check soon
Sent from my GT-N7100 using Tapatalk
Can i ask for help here, i lifted off one pad from my ktag, and i cant find now where it should connect it to make it work. I marked it with yellow, its one of the pads that should be connected with white wire. i tried to solder wire, but it was too thick, and i lifted the whole pad as marked ... i preheated it i think, and it felt with the wire ;( I need to know where is it going, so i can fix it ...
