post here bdm to go file
Does anyone know OR have of a BDM Unpacking tool , so i can unpack the Bdm to go files.....?
other than winols....?
because that a bit expensive.....
I have had an authentic EVC Bdm to go Device for years.....
but never was able to unpack original file reads....and i do need this from time to time...NOT TUNED FILES...Original.... ;-)
id appreciate the help?
thanks alot....my freinds!
K
The difference between men and boyz...Is the price of there Toyz.
LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
Hicarmageddon......
Thanks alot for offering your help.....
i was asking because its a pain to read and post to unpack , then modify, and post it again to re pack, and get it back....i was wondering of there was anything other solution around that i can have to do it on my own ;-)
again bud thanks for the help offered!
K
Doesn't make sense, what are using to edit the files?
Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
Hello
Original Tools will be supported. Post your BDM read out here and we will help to unpack it.
Hello Friend,
original Files you can unpack / read with Winols. File Format was changed often.
You can tune he Files and resave as .bdmtogo
Problem is at Checksum correction. Which version of bdmtogo sw you used ?
Send files i can do this for you.
