For those who want codes for fords, I found this website ford blaupunkt codes M,V, C7, BP serials accepted...
Code by serial:
Chrysler:TxxQR;TxxAN;TxxQN;T0012;T0071;T00AM;TVPQN;T19A1;T1 9A2;T0MYD;T0BYD;T00AD
MB Comand: NTG2.5;NTG4;NTG5
Gathers: VSM145C;VSM145VFEi;VXM155C;VXM-175VFi
Nissan: BOSCH LCN;Clarion;Daewoo
Hi all, please code for
8S7T 18K931 AC
881 C7E3A0522 8 8143493
7 612 300 522
dttamas (17th August, 2020), nelutzul40 (17th August, 2020)
Thank you very much for your help.
Hi all
I need code for ford navi
217 C7E3A0536 8 8254261
8S7T 18K931 BB
7 612 360 536
waldi
waldi (4th November, 2020)
hi all! please radio code ford ls
7M5T 18K931 AE
881 C7E3A0516 7 7316328
7 612 300 516
Try code = 4265
bogege (31st December, 2020)
Key code is not valid
svasiljev (31st December, 2020)
It is possible that in the past the radio was decoded and the original code was changed!
Maybe you not enter this code correctly!
Please note that code entry is only possible when "KEYCODE" and "1234567890" is shown in the display. If the unit is codelocked it will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" KEYCODE "
" 1234567890 "
Rotate RH Tuning Knob to Select 1st Digit
Press RH Tuning Knob to Enter
Rotate RH Tuning Knob to Select 2nd Digit
Rotate RH Tuning Knob to Select 3rd Digit
Rotate RH Tuning Knob to Select 4th Digit
If the correct code number is now shown
Press RH Tuning Knob to Enter!
catalinosonesti (31st December, 2020), masterskay62 (31st December, 2020), svasiljev (31st December, 2020)
I need code
881 C7E3A0524 9 9023109
8S7T 18K931 AD
7 612 300 524
Tnx.
